In Memory of Member 1338
Results 1 to 3 of 3
Thread: USB Cable
  1. #1
    Registered Member
    Mazda 6 Signature
    Join Date
    Jul 2018
    Location
    Boulder CO
    Posts
    14
    USB Cable
    Has anyone run a USB cable from the center console USB port to the front of the console for a phone dock?
    I'm having the CarPlay/AA upgrade done this week and want to mount a phone dock somewhere on the dash.
    Thanks
  2. #2
    Registered Member
    2016 Mazda 6
    Join Date
    Apr 2019
    Location
    Central Ohio
    Posts
    16
    Thanks for that thought. I'll be installing the new hardware this weekend, hopefully. Running a USB cable from the armrest of my Mazda 6 to the little cubby in front of the shifter will make it easier to lay the phone up there without having the cable snaking across the console.
  3. #3
    Registered Member
    2016 Mazda 6
    Join Date
    Apr 2019
    Location
    Central Ohio
    Posts
    16
    I installed the hub this past weekend. After installing the new USB "hub", I drilled a hole in the bottom of the armrest cubby near one of the lower mounting tabs and ran a USB cable from the hub under the drink holder and forward and brought it up at the front corner of rubber flat area ahead of the shifter. Works great as a place to plug my phone straight into the USB hub. CarPlay works great. Easy install.
Similar Threads
  1. HELP! Does anyone know what this cable is?!
    By Jdlarso in forum Mazda6 How-To
    Last Post: 02-25-2015, 02:37 PM
  2. VCM IDS Cable
    By ftp19601960 in forum CX-9 General
    Last Post: 12-27-2013, 03:59 PM
  3. afc cable
    By cmahlig in forum Mazdaspeed Protege
    Last Post: 07-15-2007, 11:38 PM
  4. New Sig !! (Thanks to Cable 43)
    By Subghetto in forum Lounge
    Last Post: 01-30-2005, 06:24 PM
  5. I need cable, but how much..?
    By N2OInferno in forum Mazda How-To
    Last Post: 03-19-2004, 02:22 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
