Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
Thread: P0524 Check Engine Light on 3 Month Old 2018 CX-5 AWD Touring
  1. #16
    Registered Member
    Join Date
    Mar 2005
    Posts
    29
    I got the same pcm flash after they couldn't find anything wrong. Cel has not come back.
  2. #17
    Registered Member
    Donated: $15
    2016.5 CX 5 Touring AWD, 2015 SCION XB
    Join Date
    Mar 2013
    Location
    ABE area, Pennsylvania, USA
    Posts
    1,409
    Could be an oil filter thing, too. Throw out that Mexican filter and get one from Thailand, lol.
  3. #18
    Registered Member
    Join Date
    Oct 2017
    Posts
    1,320
    Quote Originally Posted by yrwei52 View Post
    Thanks for the update.
    IMO you're a victim of eased tolerance of manufacturing and your engine simply got some out of spec parts assemblied into it. The PCM updates could simply just relax the range of low oil pressure warning which won't trigger the P0524 error code like it's supposed to be. The proper fix should be like ferro_sk's Mazda dealer, but that would cost too much!
    Did you buy that RAV4 yet?
  4. #19
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,716
    Arrow
    Quote Originally Posted by Puyapim View Post
    Not yet. I usually would wait for a year or two for any new power train or new model hopefully the manufacture would fix most of problems after the new release. I did a test drive a couple of days ago on a 2019 Toyota RAV4 XLE FWD and didnít see those crappy assembly interior trims showed in the Lexus forum. Made in Japan definitely helped. My major complaint is the engine is noisy. It seems something is loose with the rattling noise even during the idle when I popped open the hood. Worse thereís no sound deadening hood liner which was there on 2018 RAV4ís! The salesman said the rattling noise is from dual injectors (direct and port) for each cylinder.
    Yeah definitely our CX-5 looks much nicer and drives quieter.
  5. #20
    Registered Member
    Donated: $15
    Join Date
    Mar 2013
    Location
    Posts
    1,409
    Not yet. I usually would wait for a year or two for any new power train or new model hopefully the manufacture would fix most of problems after the new release. I did a test drive a couple of days ago on a 2019 Toyota RAV4 XLE FWD and didn*t see those crappy assembly interior trims showed in the Lexus forum. Made in Japan definitely helped. My major complaint is the engine is noisy. It seems something is loose with the rattling noise even during the idle when I popped open the hood. Worse there*s no sound deadening hood liner which was there on 2018 RAV4*s! The salesman said the rattling noise is from dual injectors (direct and port) for each cylinder.
    Maybe they'll kaizen some improvements into the 2020 year. Was looking forward to it, too. Sounds like it's turning out to be a dud.
  6. #21
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,716
    Arrow
    Quote Originally Posted by madar View Post
    Actually the Dynamic Force 2.5L and 8-speed auto on RAV4 have been out for more than a year since 2018 Camry. I wouldn't worry too much on reliability for the drive train. The noisy engine during idle is a surprise but shouldn't affect the reliability. 203 hp feels a little stronger than my 2016 CX-5. And the main thing for me is the fuel economy on this new drive train. Based on EPA FE estimates and real-world data from Fuelly on 2018 Camry, a better fuel economy than my CX-5 is real. Honestly with everything considered, I may have to re-consider a 2019/2020 CX-5 Signature as it'd be cheaper than a full-loaded RAV4 Limited AWD. Between 2 devils (for me) of cylinder deactivation and turbo charger, I may choose turbo. But fuel economy on 2.5T is pitiful.
  7. #22
    Registered Member
    Donated: $15
    Join Date
    Mar 2013
    Location
    Posts
    1,409
    Guess I'll have to decide for myself next model year and check them out. I like the fact that you can choose which AWD mode that you want.
  8. #23
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,716
    Arrow
    Yeah we have to set our own priority straight as thereís no perfect car available for us. My first priorities are reliability and fuel economy. I donít care too much on power as the power of my current 187hp 2.5L 2016 CX-5 is good enough for me. Thereíre many configurations on new RAV4 with different AWD setups. Unfortunately we canít find any AWD in Texas unless the trim level has AWD as the default. Iíve to decide between RAV4 Limited or CX-5 Signature which will only come with AWD.
  9. #24
    Registered Member
    2018 CX5 GT
    Join Date
    Feb 2019
    Location
    A cave somewhere in Afhganistan
    Posts
    1
    There is a TSB for this and it is strickly for 2018 CX 5 with VINS lower than JM3KF******406225. These have a manufacture date before May 7, 2018.
    The issue is software code that controls the engine oil valve and causes it to work too slowly in certain situations. This results in engine oil pressure rising too slowly and setting a low oil pressure OBD code PO 524.
    Dealer will check oil pressures and as long as it meets spec, the update to the PCM with be performed. TSB was issued 10/18/2018 TSB # 01-020-18
  10. #25
    Registered Member
    cx5 gt +pp 2018
    Join Date
    Dec 2018
    Location
    arizona
    Posts
    218
    here are the normal oil pressures excpected
    RPM Normal oil pressure
    650 50 kpa (7 psi) or more
    1,500 110-175 kpa (16.0 - 25.3 psi)
    4500+ 300-430 kpa (43.6 - 62.3 psi)
    it can be viewed through obd.
  11. #26
    newfound love for my MS3! 08MicaMS3's Avatar
    2018 Mazda CX-5
    Join Date
    Feb 2008
    Location
    Chicago, IL
    Posts
    35
    Thanks for this thread.
    Wife was driving to Milwaukee this morning and out of no where the oil light popped on, so having no idea had her drive it home to be safe. Then found this thread.
    2018 Mazda CX-5 with VIN ending 323***, called my dealer and scheduled an appointment for today. Will loop back.
  12. #27
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,716
    Arrow P0524 Check Engine Light on 3 Month Old 2018 CX-5 AWD Touring
    Quote Originally Posted by flimflamman View Post
    Ha this TSB somehow makes me believe this's related to cylinder deactivation from 2018 CX-5! We have no such issue before, and started happening from MY 2018. And the falling rocker arm problem is also related the oil pressure been adjusted too low, at least according to Mazda although IMO there's definitely more involved but Mazda is just not willing to tell.
  13. #28
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,716
    Quote Originally Posted by 08MicaMS3 View Post
    How many miles on your 2018 CX-5? Have you changed factory oil yet?
    Actually your situation is DIFFERENT from what was described in this thread. Those with problem in this thread had only CEL with P0524 error code, but they didn't have Low Oil Pressure Warning light. Yours has Low Oil Pressure Warning light on without CEL, which is definitely more serious!
    You should use free Mazda road service and tow your CX-5 to your dealer as you never know what is going on when the low oil pressure light is on. And when this light is on, it means your engine has low oil pressure which will damage the engine. The owner's manual says don't drive, tow it to the dealer.
  14. #29
    Underutilized Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    State of Jefferson
    Posts
    1,924
    That was not the safe decision. When the oil pressure light goes on STOP THE ENGINE. To keep driving risks a seized engine. You were lucky this time.
  15. #30
    2018 Mazda CX-5
    Join Date
    Feb 2008
    Location
    Chicago, IL
    Posts
    35
    Oil pressure light did not stay on nor did it come back after restart. Oil level was fine. 12000 miles and had its first oil change at 7500.
Similar Threads
  1. check engine light on new 2018 CX-5
    By CX5Nut in forum CX-5 Lounge
    Last Post: 07-28-2018, 07:02 AM
  2. Wrench Light & occasional check engine light ONLY DURING WET SNOW
    By busded in forum CX-9 Engine & Transmission
    Last Post: 02-24-2018, 06:47 PM
  3. 2013 CX-9 Touring - Check Engine light came on...then went off...
    By Senor Valasco in forum CX-9 Engine & Transmission
    Last Post: 11-08-2015, 08:00 AM
  4. Replies: 3
    Last Post: 11-09-2014, 05:24 PM
  5. Replies: 6
    Last Post: 07-22-2014, 12:27 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
