Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: P0524 Check Engine Light on 3 Month Old 2018 CX-5 AWD Touring
  1. #1
    Registered Member
    Join Date
    Mar 2005
    Posts
    29
    Anyone had this happen to them? The fault code is P0524 - Engine Oil Pressure Too Low.
    1. Oil level is ok, right in the middle of the high and low marks on dipstick
    2. Car has 4,900 miles, almost all of it highway
    3. Bringing to dealer as soon as they have a loaner available. They said this is not common for a new car.
  2. #2
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,714
    Arrow P0524 Check Engine Light on 3 Month Old 2018 CX-5 AWD Touring
    Quote Originally Posted by changes13 View Post
    Have you ever changed the factory engine oil yet? How many miles left on your oil life monitor in Vehicle Status Monitor?
  3. #3
    Registered Member
    Join Date
    Mar 2005
    Posts
    29
    Original oil. Flexible maintenance schedule says 2200+ miles remaining.
  4. #4
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,714
    Other than P0524 CEL, did you see any other warning lights such as "low engine oil pressure" warning light flickering or on at all? Does the CEL keep on even right now? With low engine oil pressure, I'd try not to drive the vehicle as much as possible until the issue gets resolved.
  5. #5
    Registered Member
    Join Date
    Feb 2018
    Location
    Canada
    Posts
    63
    Please keep us posted
  6. #6
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,794
    I have the dealer tow it. That lite ICON says the pressure could be anywhere from 12 psi to zero. Ed
  7. #7
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,107
    Hmm interesting. So there could be some internal bearing issue that is affecting oil pressure and they want you to keep driving it..
  8. #8
    Registered Member
    Join Date
    Mar 2005
    Posts
    29
    Only cel light. No oil light on. Car seems to run ok other than a bit of elevated rpms occasionally.
  9. #9
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,107
    The teapot blipped (probably didn't notice since apparently it didn't stay on), and DTC was stored.
    DTC P0524:00 Engine oil pressure too low
    DETECTION
    CONDITION
    l The oil pressure switch is on for a continuous 5 s with the following condition met: (engine oil warning light illuminates
    when 1 s has elapsed)
    n When engine speed is above 650 rpm and engine coolant temperature is 30 C {86 F} or less
    n When engine speed is above 1,500 rpm and engine coolant temperature is 68 C {154 F} or less
    n When engine speed is above 2,500 rpm and engine coolant temperature is 68 C {154 F} or more
    Diagnostic support note
    l This is a continuous monitor (other).
    l The check engine light does not illuminate.
    l FREEZE FRAME DATA (Mode 2)/Snapshot data is not available.
    l DTC is stored in the PCM memory.
    FAIL-SAFE FUNCTION Not applicable
    POSSIBLE CAUSE
    l Engine oil leakage
    l Improper engine oil level
    l Oil pressure switch connector or terminals malfunction
    l Short to ground in wiring harness between oil pressure switch terminal A and PCM terminal 1P
    l PCM connector or terminals malfunction
    l Oil pressure switch malfunction
    l Oil pump malfunction
    l PCM malfunction
    file:////
    I guess technically it's possible to trigger it by exceeding certain RPMs with low coolant temp (i.e right after a cold start) for at least 5 seconds
  10. #10
    Registered Member
    Mazda CX-5 (KF) G194 AT AWD Revolution TOP
    Join Date
    Apr 2018
    Location
    Slovakia
    Posts
    5
    I had Check Engine Light issue on my new Mazda CX-5 KF too (2.5l petrol engine with cylinder on demand technology, G194). It happend 2 months after buying a car with around 1800km on it. I had not noticed any issue with the engine all looked normal when CEL turned on. I took it to dealership ASAP. They checked oil level and put on diagnostic. They found some error code (I don't have number sorry) but they just reset it, made some test ride and returned car back to me. Problem re-occurred again after around 100km. I took it at the dealership again immediately. They discussed the problem with Mazda support and replaced oil control selenoid valve, oil pump, oil pressure sensor and also connecting rod bearings (metal set conn.rod). It took almost 2 months until I got the car repaired back but it was mostly because it was new model, new engine and they did not have required spare parts on stock in EU at that time. When they got all spare parts it took 1 day to replace them. Now I have around 11000km on it (6 months since the repair) and engine is working fine no any issues so far. I know at least about 2 other people in our country (Slovakia) who had the same issue and some people in Germany reported the issue as well.
  11. #11
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,107
    Quote Originally Posted by ferro_sk View Post
    Welcome. Glad the issue was addressed.
  12. #12
    Registered Member
    2018 CX-5 GT
    Join Date
    Apr 2018
    Location
    Mitten
    Posts
    2
    Hi,
    Did you get the issue resolved?
    My 2018 GT also just randomly illuminated the CEL and has this same code now!?!
    Very concerned at the moment. Only has 11,200 miles, and 2 oil changes both performed at the Dealership where I purchased...
  13. #13
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    7,439
    Its the displacement on demand!!! *runs and hides*
  14. #14
    Registered Member
    2018 CX-5 GT
    Join Date
    Apr 2018
    Location
    Mitten
    Posts
    2
    Quote Originally Posted by SpeedHoles View Post
    Hi,
    Just an update here, took 10 days for the dealership to fit in an appointment for us (then of course we get there and the service manager asks "what took you so long to bring the vehicle in..."
    In the meantime, I checked the oil level (both hot and cold to compare), and hot it was slightly lower at about 80% up to the full dot on the dip stick.
    Anyway, they tried to blow it off, not even mentioning there was a fault code, no less speak the words "oil pressure low" aloud. Just had the vehicle for a couple of hours then said, "it's all fixed now, you're all set."
    I basically had to call them out and tell them I read the code, I know what the code is and I've documented it on my own, now they have to document it in their records incase further related issues arise in the future.
    I was then told they checked the oil pressure, it was "within spec", and the tech found a TSB related to the issue and they reflashed the PCM with an update.
    This is marked on my paperwork as TSB Number 01-020/18
    And the PCM update performed per TSB XXP67XFX
    Now, let's see if the check engine light gets triggered again...?
    Knock on wood this really was a non issue.
    But I lay in bed at night just imagining there may have been a true low oil pressure scenario and it possibly began wiping a rod or crank bearing...
    Anyone else have a CX-5 in for that same TSB?
  15. #15
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,714
    Just an update here ⋯
    Thanks for the update.
    IMO you're a victim of eased tolerance of manufacturing and your engine simply got some out of spec parts assemblied into it. The PCM updates could simply just relax the range of low oil pressure warning which won't trigger the P0524 error code like it's supposed to be. The proper fix should be like ferro_sk's Mazda dealer, but that would cost too much!
Similar Threads
  1. check engine light on new 2018 CX-5
    By CX5Nut in forum CX-5 Lounge
    Last Post: 07-28-2018, 07:02 AM
  2. Wrench Light & occasional check engine light ONLY DURING WET SNOW
    By busded in forum CX-9 Engine & Transmission
    Last Post: 02-24-2018, 06:47 PM
  3. 2013 CX-9 Touring - Check Engine light came on...then went off...
    By Senor Valasco in forum CX-9 Engine & Transmission
    Last Post: 11-08-2015, 08:00 AM
  4. Replies: 3
    Last Post: 11-09-2014, 05:24 PM
  5. Replies: 6
    Last Post: 07-22-2014, 12:27 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
