Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 46
Thread: Only OEM windshield for now.
  1. #31
    Registered Member
    2017 CX5 GT FWD
    Join Date
    Oct 2017
    Location
    STL
    Posts
    82
    I just drove away from Safelite in Missouri. The windshield is on back order after mine cracked (and continues to crack) after a rock chip. This will cost me $566, when a windshield becomes available. This could take weeks though.
  2. #32
    Registered Member
    2016 CX5 GT /Tech
    Join Date
    May 2015
    Location
    Minneapolis
    Posts
    15
    My 2016 CX5 GT just got a cracked windshield again. First one was replaced in 2015, back then it took over 3 month to get a new windshield.
    It appears if the hit is near the edge it will crack very easily.
    https://www.mazdas247.com/forum/show...GT-w-Tech-pakg
  3. #33
    Registered Member
    Join Date
    Nov 2019
    Posts
    1
    I have done my windshield replacement in 2018 and till now it's clean and clear and t's been done by safelite.
  4. #34
    Registered Member
    Cx-5 Sport
    Join Date
    Nov 2019
    Posts
    34
    My 16 has about three hits on it now. A couple of streaks along the right side that I couldnt glue quick enough.
    I try to always carry a RainX kit. I think they have the best glue. If you glue a star right away it works best. If you wait til you get to a shop it can and usually will spread.
    I kind of think one of them was spontaneous or due to a defect but I wonder if the newer OEM windshields are thicker?
  5. #35
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,446
    Arrow Only OEM windshield for now.
    Quote Originally Posted by Mazdiod2 View Post
    ⋯ I kind of think one of them was spontaneous or due to a defect but I wonder if the newer OEM windshields are thicker?
    Yeah the windshield on newer gen-2 CX-5 is definitely a bit thicker due to the use of acoustic laminated glass. But this doesnít mean itíd be stronger against rock-hit.
  6. #36
    Registered Member
    cx5 gt +pp 2018
    Join Date
    Dec 2018
    Location
    arizona
    Posts
    341
    driving in Arizona means going through windshields faster than tires + so many people drive huge work pickup trucks with large tires and throw small stones everywhere on the city highways.
    I also keep RainX chip repair at hand.
    To me it seems the 2nd gen windshield is very fragile too. I usually have to repair at least 1 chip every other month.
  7. #37
    Registered Member SixPackABS's Avatar
    CX-5 2017 GT AWD
    Join Date
    Nov 2017
    Location
    New York
    Posts
    171
    My CX5 GT 2017 had a windshield replacement in the just less than a year. The glass was replaced and done by Safelite.
  8. #38
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,354
    Made in USA Pilkington windshield here. OEM supplier for Lexus and others. In Arizona Insurance companies are required to offer windshield coverage but not include it to coverage . It's a groovy windshield to rock (no pun intended)
  9. #39
    Registered Member
    2019 Mazda CX-5 GTR
    Join Date
    Feb 2019
    Location
    Plymouth MA
    Posts
    184
    I've replaced two windshields on my GTR since buying it last Feb. The first was in March and the second two weeks ago. Safelite could not find a windshield in stock anywhere and told me they were on national backorder. I called the dealer and they found one in 10 minutes. They recommended a mobile service and it was replaced two days later.
  10. #40
    Registered Member
    Cx5
    Join Date
    Jan 2019
    Location
    Vermont
    Posts
    128
    Quote Originally Posted by pcardoza View Post
    Were they OEM replacements each time?
    Have the wiper heaters, rain sensors and cameras been working as expected since the replacements?
    I have a star the size of a quarter that Iím not sure will make it to the shop without cracking. although I did already drive 30 miles back from the mountain with it.
  11. #41
    CX-5 2017 GT AWD
    Join Date
    Nov 2017
    Location
    New York
    Posts
    171
    Quote Originally Posted by 2001birdowner View Post
    I have a star the size of a quarter that I*m not sure will make it to the shop without cracking. although I did already drive 30 miles back from the mountain with it.
    Safelite did the necessary calibration. No problems after installation.
  12. #42
    Registered Member
    2019 Mazda CX-5 GTR
    Join Date
    Feb 2019
    Location
    Plymouth MA
    Posts
    184
    My GTR did not get re-calibrated after either windshield replacement and everything works perfectly.
  13. #43
    Registered Member
    Cx5
    Join Date
    Jan 2019
    Location
    Vermont
    Posts
    128
    So far I got lucky and they were able to fill it. Still a visible star, so Iím concerned it will eventually crack.
    I must say this windshield can take a lot more than the first gen.
    This was a pretty big rock. Low speed but big hit.
  14. #44
    Work in Progress sm1ke's Avatar
    Contributor
    2018 Mazda CX-9 Signature
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    2,152
    So far I got lucky and they were able to fill it. Still a visible star, so I*m concerned it will eventually crack.
    From personal experience, if you get the star filled/repaired, it shouldn't crack any further. The first car I had ('84 Chevy Celebrity), I got a star crack from a semi that was throwing up rocks and gravel. It was small, maybe the size of the eraser on a pencil. It happened in the fall, and overnight, the crack expanded all the way across the windshield due to the temperature changes. Since that car, whenever I get a star/chip/crack on my windshields, I get it repaired as quickly as possible.
  15. #45
    Registered Member
    Cx5
    Join Date
    Jan 2019
    Location
    Vermont
    Posts
    128
    Quote Originally Posted by sm1ke View Post
    Iíve had plenty of chips repaired before but never one with a star like this, so Iím just not as not as optimistic.
    They didnít say anything one way or the other, so time will tell.
Similar Threads
  1. 2016 Windshield sensors and correct windshield
    By cat27sailor in forum Mazda6 How-To
    Last Post: 03-04-2016, 01:56 PM
  2. Replies: 2
    Last Post: 06-15-2010, 09:58 PM
  3. Windshield
    By SkinnyJoint in forum Protege5
    Last Post: 02-10-2005, 07:26 PM
  4. windshield?
    By traitorhound in forum Protege5
    Last Post: 01-14-2003, 08:53 AM
  5. Windshield
    By barberella76 in forum Protege5
    Last Post: 12-05-2002, 11:34 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
