Before I call dealer which is not always fun, can some one try this. Lock auto any way you want. Try liftgate with key in pocket. Opens or locked? Mine opens and only locks with key out of range. Doors are locked. Thanks
Thank you. I was expecting it to be locked, same as if I tried a door. Sometimes I check to make sure if I locked up and was surprised the liftgate opened.
And if you have the car in acc mode, it will open when the door is unlocked and it won't if the door is locked regardless if you have the key fob with you or not.
Correct, my 2014 works this way as well. If your doors are locked and you have the fob the lift gate will open. When you close it, it will return to the lock position so no worries walking away.
