Page 5 of 18 FirstFirst ... 3456715 ... LastLast
Results 61 to 75 of 262
Thread: Transmission fluid change without filter replacement
  1. #61
    Gen-1 Kodo Design 👌 ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,367
    Thank you yrwei! I appreciate it
    I'll probably do 2 drain/fills. Going to place an order for the ATF fluid this week.
  2. #62
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,245
    Arrow Transmission fluid change without filter replacement
    Quote Originally Posted by ColoradoDriver View Post
    Are you going to get FZ ATF from tascaparts.com suggested by Kedis82ZE8?
    You also have to decide which way you're going to reach the ATF dipstick. Personally I'd go from bottom side like tomcat1446 suggested. Make sure to clean up the AFT dipstick area first or the dirt will fall into the transmission! See post #103 by tomcat1446.
  3. #63
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,367
    Quote Originally Posted by yrwei52 View Post
    I was, but I just looked to go order and it says "call for availability" so I wonder if they sold out on that price. Will call and find out. I'm not keen on buying 10 bottles at $15/each unless I have to I suppose.
    Regarding access to the dipstick, may be hard to see that I'm not knocking dirt into the hole if I am doing it from the bottom isn't it?
  4. #64
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,245
    ⋯ Regarding access to the dipstick, may be hard to see that I'm not knocking dirt into the hole if I am doing it from the bottom isn't it?
    Read tomcat1446'a post and he has very detailed description.
  5. #65
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,312
    I prefer access from the top
    On a serious note....only becuase that FZ oil is super super slick and thin. Easy for it to be flung into eyes/face.
  6. #66
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,367
    Quote Originally Posted by CX-5um View Post
    Yeah I think I am going to go this route.
  7. #67
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,245
    Then you have to have the engine running without the airbox while you're measuring the ATF level. Not only the dirt may get sucked into the engine, but also a CEL is expected without the airbox.
  8. #68
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,312
    I cleaned the engine bay and worked inside a garage. unbolted the air intake nuts above radiator but kept intake hose (MAF) connected to engine at all times. no CEL and just moved box out of way each time I checked levels.
    Engine wont even start without air box(MAF connected). I tried and it just stalls
    I had success removing measured amount at cold ambient temps.....replacing measured amount at cold ambient temps. Dip stick is in spec when cold and Still in spec when hot (past 122 degrees). So far so good for me.
  9. #69
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,245
    Thanks for the info. So basically you said it's possible to keep the air filter box and MAF connected all the time, but only move the whole air box around to access the ATF dipstick? If this's the case then I believe accessing from the top is indeed a better way!
  10. #70
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,367
    Yeah. Assuming the level is not too low to begin with, I don't understand why you can't just measure what you take out and put the same amount new back in. Makes sense to me?
    It's not like the new fluid you put in is at 122 degrees.
    Can someone explain that one for me?
  11. #71
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,312
    Correctomundo. I originally took off the entire airbox and piping, ect for clearance. Car would not start. Proceeded to put everything back together and car started. Its been awhile but on my 3 attempts between the m6 and cx-5 I've always had the airbox connected. Just take your time and ease the thing to the side.
    To be honest now I may have removed the section between airbox to inlet on top of radiator. This section is what gets in your way from dipstick. The airbox with MAF sensor was definitely in place.
    I may have also kept everything in 1 piece and simply move sections aside. Chances are I probably did both ways.
  12. #72
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,831
    Blog Entries
    6
    I'm gonna put mine up on 4 ramps and come in from the bottom. I can reach the dipstick from the underside with splash shield off. I think when I first checked my fluid I used some long reach socket extensions and and as well as as some long reach pliers. I didn't need to remove anything other than the bolt holding the dipstick in. I got the bolt on dipstick loose enough I could extract the bolt with one of those long reach HF tools with the spring loaded grabber on the end.
    ColoradoDriver: That should be fine. Just make sure new fluid is same temp give or take a couple degrees and replace on volume removed & replaced... you can always weigh fluid as well and then the temp won't matter.
    '15 CX-5 GT 2.5L w/tech package - 53K Miles - https://www.oemvehicleparts.com/ (30% off "shipping" with code "MAZDAS247")
  13. #73
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,367
    Thanks guys. I think I have a plan for attack now. I took some extra time to read through some threads.
    Will warm up the engine and then check current level to see if it is low and then adjust what I put in from there.
  14. #74
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,245
    The reason why you don't put the same amount of fresh ATF drained out back into the transmission is because the factory-fill could be low been reported by many. Other cases the old ATF level could be too high as the result of over-fill by the Mazda dealer. So take time to measure the old ATF level first before you drain it.
  15. #75
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,367
    Got it.
    Will do that's I don't have or know how to use those scan tools to measure actual temp, so is the consensus that it is good to measure after the blue light turns off?
Similar Threads
  1. Transmission Fluid and Filter
    By upthemiddle in forum Mazda2 General
    Last Post: 11-23-2013, 01:47 PM
  2. transmission fluid change
    By abkdt41 in forum Mazda Protege
    Last Post: 01-21-2013, 11:59 PM
  3. Tranny fluid and filter change how to????
    By Expygator in forum CX-9 How-To
    Last Post: 06-28-2009, 10:53 PM
  4. How to change transmission fluid
    By volks1218 in forum Mazda5
    Last Post: 10-21-2008, 12:47 PM
  5. transmission fluid change
    By samsel450r in forum Mazda3 How-To
    Last Post: 06-20-2008, 05:32 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
