Page 2 of 18 FirstFirst 123412 ... LastLast
Results 16 to 30 of 262
Thread: Transmission fluid change without filter replacement
  1. #16
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,312
    Quote Originally Posted by Humid Hummus View Post
    If the filter has enough material on it to cause blockage, that means you did not maintain your transmission properly and a drain/fill will simply increase the chances of breaking those little shavings free and getting them stuck in one of the transmissions many intricate passageways. This is why I recommend not to touch your transmission at all if you don't plan on changing the pan filter, because you're just going to have more problems.
    ^^this represents 1/2 of why you should not touch the tranny (if never serviced) past 100k miles. The other half is that the metal shavings (ARE) beneficial to the system.
    Over time, Larger bits are stuck on magnet/filter. Smaller bits become crucial lubricant for moving friction parts (now with gaps due to metal shaving). When removing the fluid/filter you may:
    -Agitate the Larger bits to cause clogging.
    -Moving friction parts has these gaps which rely on small metal shavings. Not having small shavings means mechanical failure risk.
  2. #17
    Banned
    2016 Mazda CX-5
    Join Date
    Aug 2018
    Location
    Ontario
    Posts
    16
    Quote Originally Posted by CX-5um View Post
    This only becomes an issue after about 150K+ miles. At 100K there really is no risk to change your transmission fluid and pan filter, as the transmission is not relying on those little metal bits for friction just yet. Better late than never. Ask me how I know...
    If you are changing your pan filter by 125K or so, whatever leftover metal particles will get caught by the new magnet filter. This is why so many people advise against a simple drain/fill at this mileage, because those metal particles are much less likely to get caught by the old original filter.
  3. #18
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    7,980
    Well, at 110K is when I did my Infiniti, or rather when the dealer did. Drain and fill, with filter swap. 5K miles later, it was deader than dead. Torque converter, too.
  4. #19
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,244
    Arrow Transmission fluid change without filter replacement
    Incorrect. The transmission filter also has a magnet which traps metal shavings that break off from the transmission components. If you dropped your pan and looked at this filter after 60K, you'll be happy you did.
    No, the ATF filter cartridge (#5) inside of SkyActiv-Drive transmission has only regular *paper* type filtering material. The magnet is built into the ATF pan.
    No, the ATF, not like engine oil, is relative clean during its service life as the transmission is a *sealed* environment. The service life on this ATF cartridge is long and the metal shavings if any won*t get loose with drain-and-fill. Even if some larger shavings get loose they will get stopped by the filtering element again and won*t get into the passages of valve body. Metal shavings are heavier and most likely will stay at the bottom of the ATF pan and are kept there by the magnet.
    Changing the ATF filter/cartridge during the ATF change is a good practice. But our SkyActiv-Drive ATF pan uses silicon sealer which is hard to apply properly, and the factory service manual mentions only drain-and-fill procedure, not with filter / cartridge change.
  5. #20
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    7,980
    Quote Originally Posted by yrwei52 View Post
    It's not hard to apply properly at all. If your dealer says so, it's because they have inexperienced techs and do so few of them. Other brands do that every 30 to 50k miles without ever an issue.
  6. #21
    Structural Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD PP
    Join Date
    Oct 2017
    Location
    State of Jefferson - SO Oregon
    Posts
    2,621
    Quote Originally Posted by Unobtanium View Post
    A great argument against a weekend warrior tackling the job.
  7. #22
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,244
    Quote Originally Posted by shadonoz View Post
    Similar to a good caulking job, it definitely is not an easy job at least for me. You don’t want to apply too much silicon sealant which may get squeezed out and fall into the ATF pan; too little may fail to have a good sealing function.
  8. #23
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,244
    My opinion on ATF change is the same as this Scotty Kilmer guy ⋯
  9. #24
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,831
    Blog Entries
    6
    IMO... if you have enough metal to clog up that AT filter one has bigger issues than just bad fluid.
    I'm gonna do my partial change really...really soon.. I'm still at around 45-46K miles.
    '15 CX-5 GT 2.5L w/tech package - 53K Miles - https://www.oemvehicleparts.com/ (30% off "shipping" with code "MAZDAS247")
  10. #25
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,244
    Quote Originally Posted by Kedis82ZE8 View Post
    I agree.
    I wouldn’t worry too much to drain-and-fill the ATF at 46K miles. I plan to do mine after 50K miles.
    Have you done anything on your small engine oil leak?
  11. #26
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,831
    Blog Entries
    6
    I agree.
    I wouldn*t worry too much to drain-and-fill the ATF at 46K miles. I plan to do mine after 50K miles.
    It has again apparently subsided for the summer but I'll report back if it appears more noticeable when I partial change AT fluid. Not forgotten :-)
  12. #27
    Registered Member
    Donated: $15
    2016.5 CX 5 Touring AWD, 2015 SCION XB
    Join Date
    Mar 2013
    Location
    ABE area, Pennsylvania, USA
    Posts
    1,468
    Yep, if you have a clog the thing won't even run
  13. #28
    Registered Member
    Mazda CX-5 AWD GT
    Join Date
    Dec 2017
    Location
    TN
    Posts
    10
    Finally got around to the AT drain & refill at 103K miles. Drained fluid looked like strong coffee! Will repeat two more times with about 1K miles in between. Highway driving is about 65% of my miles. Definitely won't wait so long on any future car with "lifetime" fluid. Transmission seems to shift more smoothly, but could just be me. Wasn't experiencing any issues previously just trying to get the most miles on this vehicle as possible.
  14. #29
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,244
    Quote Originally Posted by LRopka View Post
    Great to have enough courage doing the first ATF drain-and-fill at 103K miles! Honestly I’d do the same no matter what. Hope you have nothing but good results from your ATF change. One thing I wouldn’t do is to wait for 1K miles for the next 2 changes. The fresh and old ATF will be fixed immediately by the ATF pump. I’d wait for a week or two, or a couple hundreds of miles in between to do the subsequent ATF changes. I imagine you used only genuine Mazda ATF FZ, nothing else.
  15. #30
    Gen-1 Kodo Design 👌 ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,367
    Where are you guys buying this stuff as I have checked a few Mazda sites and they don't have it.
Similar Threads
  1. Transmission Fluid and Filter
    By upthemiddle in forum Mazda2 General
    Last Post: 11-23-2013, 01:47 PM
  2. transmission fluid change
    By abkdt41 in forum Mazda Protege
    Last Post: 01-21-2013, 11:59 PM
  3. Tranny fluid and filter change how to????
    By Expygator in forum CX-9 How-To
    Last Post: 06-28-2009, 10:53 PM
  4. How to change transmission fluid
    By volks1218 in forum Mazda5
    Last Post: 10-21-2008, 12:47 PM
  5. transmission fluid change
    By samsel450r in forum Mazda3 How-To
    Last Post: 06-20-2008, 05:32 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
