Results 1 to 10 of 10
Thread: Brakes Servicing - recommended?
  1. #1
    Registered Member
    2017 CX9 Sig
    Join Date
    Jan 2018
    Location
    Cda
    Posts
    81
    Just wondering with any of you owners if you've found it necessary to have the CX9's brakes serviced specifically cleaning of the discs, rotors and pads? Came to my local Mazda dealer for a change oil svc 3wks ago and they recommended this with the changeoil for approx $200 CAD and is recommended for yearly service...my 2017 Signature has only 15K Kms ODO and is only 1.5yrs old but never had this svc done. They said it is part of the preventive maintenance service and is found in their maintenance schedule. So far I don't notice any brake fade or any hissing sound or other issues on the brakes. Is this a good idea/necessary to service at that interval?
  2. #2
    Registered Member
    Join Date
    May 2012
    Location
    NY
    Posts
    138
    Key word there is "THEIR" as in "their maintenance schedule". For the most part I think they just make stuff up in order to sell it. Additionally, they pretty much usually cut the manufacturer specified maintenance schedules in half by recommending things a long time before the actual Mazda factory schedule. I would, and always have, stuck to the factory schedule and ignored all that up-sell nonsense at the dealer. They work on an incentive plan back in service as well and their pitch is not always in your best interest.
  3. #3
    Registered Member
    2017 Mazda 6 Sport
    Join Date
    Feb 2018
    Location
    TX
    Posts
    155
    Owner's manual just says to inspect the brakes at 24k km/15k miles or once a year under the Canadian maintenance schedule. The US schedule says to inspect them at each oil change
  4. #4
    Registered Member
    2016 cx-9 signature
    Join Date
    Nov 2017
    Location
    San Francisco, CA
    Posts
    102
    What they gonna do? Take the wheel off and spray some brake cleaner on the caliper and pads and wipe it down with a rag and put the wheel back on and charge you $200?
    I would rather do that myself... hell I*ll do the same for you for $100....
  5. #5
    Registered Member
    2018 CX-9 SIGNATURE
    Join Date
    Sep 2017
    Location
    TN
    Posts
    174
    Quote Originally Posted by tekz View Post
    The head mechanic at my dealership said under normal driver conditions, I shouldn't have to have any brake work done until 80-90k miles or beyond. He also said he hasn't yet done one brake job on the '16+ CX-9's.
    He didn't mention any maintainance.
  6. #6
    Registered Member
    2017 CX-9 Signature & 2019 CX-3 GS AWD
    Join Date
    Feb 2015
    Location
    Canada
    Posts
    373
    I figured especially with the mileage I have and considering I just had the brakes inspected last fall during a routine maintenance work that this wasnít necessary. My prev Volvo XC60 had brakes serviced (pads replaced) only once in my 7yrs of ownership. Iíll have the brakes inspected on my next tire rotation scheduled if indeed the cleaning is necessary but I highly doubt it will be. Btw the $200 svc that Mazda local dealer was asking for includes the change oil and filter service...but still approx $120-130 for just the cleaning is expensive. Thanks to those who gave their inputs!
  7. #7
    Registered Member
    Mazda CX-9 Grand Touring 2016
    Join Date
    Sep 2016
    Location
    Washington, the state
    Posts
    528
    SCAM
    Find a new repair shop. That C$200 = US$157. RUN!
    If you live in an area that uses great amounts of salt on the roads in the winter, and if there are many reports of brake problems in every spring and summer, maybe that service is a good idea as soon as they stop using the salt at the end of winter. I've never heard of that sort of problem, and I doubt they'd actually do any work on the brakes, anyway. Maybe when the tires are rotated they'd spray some solvent on the brake assemblies, wipe it with a rag, and charge you the C$200. RUN!
  8. #8
    Registered Member
    CX-9 Signature
    Join Date
    Sep 2016
    Location
    Canada
    Posts
    69
    I was under the impression this service took the caliber off, disassembled the slider/clips and regreased the clips...prevents seizing in corrosive environments.
    Other Mazdaís I have had used this process.
  9. #9
    Registered Member 1987cp's Avatar
    2012 Mazda5 Touring; 2016 Mazda3 Sport
    Join Date
    Jan 2012
    Location
    Michigan
    Posts
    110
    Might depend on where you live and what the "cleaning" includes. Where I live they spread salt constantly all winter, and I just replaced my front hubs at 60k miles because the rotors were rusted in place permanently when I tried to remove them for turning.
    Having removed the rotors, wire wheeled the hubs and rotors, and applied paint, antisieze, Boeshield, or *something* every year or two would have saved a really weird headache. Ran me about $250 or $300 over budget doing it at home with used hubs ... dunno what it would have cost at the service department.
  10. #10
    Registered Member
    Join Date
    Sep 2016
    Location
    Posts
    528
    "Might depend on where you live and what the "cleaning" includes." Exactly.
    There are YouTube videos showing how to use jack bolts through the caliper mounts to get the rusted rotors loose. Alternately, one can rent a puller to get them off. If the rotors don't come loose with the jack bolts, put pressure on the rotor then give it a good rap with a heavy hammer. We don't want to pound the rotor off, just just want the rap to break it loose. Cold shocking is also a way. Heat it with a heat gun, but don't melt the bearing grease or do other damage, then dump ice water on the rotor hub. The temperature difference causes movement that can break the rust loose enough to work it off the rest of the way. The rotors will be junk either way.
    Several products work great to stop rust. Antisieze works well. Boeshield, LPS #3, ACF-50, Corrosion Block, other products. WD-40 isn't my favorite--it's a water displacer as the name says. Use the smallest possible amount; we don't want any on the braking face of the rotor.
Similar Threads
  1. stupid log book servicing
    By woot woot in forum Mazda2 General
    Last Post: 05-30-2014, 05:33 AM
  2. Brake servicing
    By merc3065 in forum CX-5 Wheels, Tires, Brakes & Suspension
    Last Post: 05-18-2014, 01:33 PM
  3. Servicing Engine on CX9
    By Johnny Mac in forum CX-9 General
    Last Post: 05-18-2014, 10:24 AM
  4. 36k mile service. What should I be servicing?
    By Marauder.45 in forum Mazda6 Engine & Transmission
    Last Post: 07-10-2009, 04:31 PM
  5. Servicing
    By SMOKINJO36JT in forum M247 News & Support
    Last Post: 12-07-2001, 10:45 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
