Page 4 of 4 FirstFirst ... 234
Results 46 to 54 of 54
Thread: Video Cleaning Intake valves CX 5 Skyactiv Gasoline engine
  1. #46
    Registered Member
    Mazda CX-5 Grand Touring AWD
    Join Date
    Aug 2018
    Location
    Colorado
    Posts
    7
    How did you rotate the engine to close the #1 and 3 cylinders?
  2. #47
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,821
    Blog Entries
    6
    OP: Thanks for video.... I guess I need to add this to maintenance list.... kinda looks like a PIA but a lot cheaper than taking to someone for a walnut blast session.
    '15 CX-5 GT 2.5L w/tech package - 50K Miles - https://www.oemvehicleparts.com/ (30% off "shipping" with code "MAZDAS247")
  3. #48
    Registered Member Kaps's Avatar
    Donated: $15
    CX-5 Touring 2016.5
    Join Date
    Aug 2016
    Location
    Lewisville North Dallas Suburb
    Posts
    2,199
    My only recollection of hand cleaned intake valves included 2-3 hours of scrubbing and using CRC for 10-15 minutes between intervals to loosen stuff out. Along with a metal bristled brush - lot of hardwork. If you were able to clean out with a toothbrush - does that mean the deposits were not too rigid or too hard?
    Official Defender of Zamdatm
  4. #49
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,249
    Quote Originally Posted by Rathfriland View Post
    This is the only thing from stopping me from doing this project= not knowing how to rotate the engine. A strong light allows you to look inside to determine which cylinders are closed. Perhaps I can clean 2 now and cross my fingers and get the other 2 cylinders closed later on LOL
    Quote Originally Posted by Kaps View Post
    The benefit from the toothbrush is no small metal bristles would fall off. Plastic toothbrush bristles usually don't fall off. The downside is less scrubbing power...........aahaaaaaaaaaa. How about an electric rotating toothbrush
  5. #50
    Registered Member
    Mazda CX-5
    Join Date
    Nov 2018
    Location
    TX
    Posts
    6
    Reviving this thread to thank Felix. I used this tutorial to do the carbon cleaning on my wife's CX-5. 70k miles and it was pretty gross. For me, the most difficult part was removing all the damn hoses and fasteners which held the sensors and wires to the intake manifold. I replaced the PCV valve while I had everything off, cleaned the throttle body, and replaced the plugs. Was in the home stretch and screwing in the top middle bolt last on the IM. Turns out I didn't have it it in the hole, and it fell through. Had to unfasten everything, remove all the bolts, and take the IM out again to fish it out.
    Good times.
  6. #51
    Registered Member
    2016 CX-5
    Join Date
    Dec 2016
    Location
    Mazdaland, Philippines
    Posts
    82
    remove the left wheel and plastic wheel well covers and turn the crank pulley. there should be a bolt forgot which size holding the pulley. use a breaker bar
  7. #52
    Registered Member
    2015 Mazda Cx-5 Touring Sport 2.5l AWD
    Join Date
    Jul 2018
    Location
    Ann Arbor, Mi
    Posts
    8
    Quote Originally Posted by Driver 1 View Post
    Jesus thx for answering this. Ive been waiting 6 mo for an answer!
  8. #53
    Registered Member
    Join Date
    May 2013
    Location
    Indonesia
    Posts
    152
    Quote Originally Posted by eelliiss View Post
    Good times.
    Welcome eelliss , Best to get a magnet tool , it is really handy and yes the middle bolt was a bit difficult to get it centered.
  9. #54
    Registered Member
    Join Date
    May 2013
    Location
    Indonesia
    Posts
    152
    correct sir as mine only 23K kms on the clock during the service.
Similar Threads
  1. Skyactiv Intake Valve carbon build up - Anyone taken a look at intake valves?
    By johnygfunk in forum CX-5 Engine & Transmission
    Last Post: 03-02-2019, 08:06 AM
  2. Replies: 0
    Last Post: 10-06-2012, 10:39 AM
  3. Replies: 2
    Last Post: 02-21-2012, 10:57 PM
  4. Replies: 2
    Last Post: 05-20-2011, 02:24 PM
  5. Replies: 15
    Last Post: 02-02-2004, 06:59 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
