2017~2024 How to stop rattling of the HUD (CX-5 2017)
CX-5 II 2.5L NA
My new CX-5 exhibits, after a couple of months driving, a rattle apparently coming out of the HUD assembly.
Anyone with the same problem? If so, how was it cured?
Eventually, how to remove and reinstall the HUD-assy?
Thank you.
You sure it's from the HUD unit? I have a rattle around that area and turns out to be the a pillar. I wedged a thick piece of foam weatherstripping on the bottom of the a pillar against the windshield and that stopped my rattling.
Tried your solution however to no avail.
It is very difficult to diagnose, rattle is not always there*..
However found out that the rattle comes from the upper steering-column cover; putting a hand on it stops the rattling noise.
Will disassemble and add pieces of double-sided tape.
