The Valvoline Advanced Synthetic has a moly-boron-titanium additive package. I’m running that right now and it’s clean as a whistle on the dipstick.
Any of the major brands now will serve you well.
I have used Pennzoil, Mobil 1, and the Mazda Moly. Overall, these 3 oils that I tried felt about the same.
All the other ones mentioned above, I have not tried. I have also heard Quaker State is good too.
If anyone has hard evidence of which oil is best for CX5, and let us know!
The undisputed champ of oils. Blackstone labs eat your heart out!!!
There really is no best when it comes to oils. All the major brands will serve you with no worries. Diligent oil changes are key.
You can spend larger amounts of $€ to get brands like Ravenol or Motul but in the end you will not notice any difference in how the engine runs. Use the latest SN+ d1G2 oils and you will be fine.
This is oh so true.There really is no best when it comes to oils. All the major brands will serve you with no worries. Diligent oil changes are key.
You can spend larger amounts of $ to get brands like Ravenol or Motul but in the end you will not notice any difference in how the engine runs.
Did oil change yesterday. Man, I highly recommend thick rubber gloves. Makes installing the oil filter by hand tightening easier than using oil filter wrenches. Fumoto drain valve still working good with no leaks.
Was at Walmart and majority of the 0w20 oils were on sale.
Ohhh one other thing......I recommend shaking the oil container vigorously. Sometimes the additive pack settles at the bottom of the bottles as per YouTube videos I seen.
Yeah, I just went ahead and got more Castrol since that is what has been used the vast majority of the life of my CX-5.
Doing my first UOA with my next change, so we'll see how the engine is looking (thumb)
All good tips. I use a cheap oil filter wrench from Walmart to loosen the filter. In most cases I can loosen it by hand if I was the one that installed it. I don’t use the wrench to tighten.
1 quick thought - at my Mazda dealership, if I order 10 (or 12 ... don't remember) 1 quart Mazda Moly at the same time (they call it a case) then 1 quart is $6.75. I found it to be quite reasonable.
Mine are 10-11$ a quart at my dealership for the OEM Moly.
They charge $59 for a Castrol oil change.
