Which coolant should I buy? Is water ok to use while I buy the proper coolant?
Thank you.
do a search next time. Here is a helpful thread I found, just go through all the posts for more info:
https://www.mazdas247.com/forum/showthread.php?123862043-Check-Your-Coolant-Level&highlight=coolant
That thread should be deleted, burned and magnetized off the servers. About the only thing correct there is that you shouldn't run straight coolant.
There's no secret that coolant level on brand-new CX-5 is low, " ~ 1" below the "Full" mark on the reservoir, from factory. Many Mazda dealers don't do the top-off during the new car inspection. The same on engine oil level and rear differential gear lubricant.I am just a bit curious as to why coolant would needed to be added so soon to a newish vehicle. Sounds like there might be an issue (uhm)
I just asked my dealer to top-off with OEM FL-22 coolant after I found out the coolant level was low from factory.
Interesting. So long as it's above the minimum level than there should be no issue.
I'm glad there is a temperature gauge in the CX-5 besides the blue temperature icon.
Still there on mineI do miss the Blue icon though ! They should have kept it along with the new coolant temp gauge.
Still there on mine
A penny saved is a penny earned!LOL. It is gone starting with the 2017 here on USA models.
It is not low. The factory has a machine that precisely meters the coolant into each car based on engineer's specifications. "Full" means don't fill higher than that allowing room for thermal expansion.
You don't need to top off a new vehicle and probably shouldn't.
New car owners get used to have all fluid levels in full for larger margin of safety. Mazda has defied convention and precisely meters many fluids so that their levels on its new vehicles from factory falls at lower than "Full" mark. From my many years of experience I've never seen a new vehicle having low oil and coolant levels in addition to 50% low on rear differential gear lub based on Mazda's factory service manual filling up the gear lub to the fill-hole. This Mazda's intentional cost-saving decision is at Mazda dealer's expense whenever a new car customer paying attention to those fluid levels, but who is going to check rear differential gear lub? My dealer is nice enough topped off my coolant 3 times with Mazda's FL-22 coolant. I'm not going to pay $24 per gallon on FL-22 coolant just for topping off.It is not low. The factory has a machine that precisely meters the coolant into each car based on engineer's specifications. "Full" means don't fill higher than that allowing room for thermal expansion.
I have it on my 17.
"You don't need to top off a new vehicle and probably shouldn't."
Then why our owner's manual always says adding enough oil / coolant "to bring the level to Full"?
View attachment 219234View attachment 219235
Where did I say we want overfill the oil? (uhm) Is this because of this post of yours?You always manage to leave enough out to make yourself look right. The few words before that line for engine oil are "if it is near or below low". Incidentally, while you're reciting the owner's manual, do you see what it says after the big caution warning right after that for the engine oil? Do not add engine oil over full. This may cause engine damage.
Where do you get this stuff???? 4.8 quarts gives puts me exactly at full with a hot engine. So now you're telling folks to overfill? C'mon.Here’s part of your problem. You need at least 5 quarts of fresh 0W-20 oil for oil change, not 4.8 quarts specified in our owner’s manual. If you want oil level reaches the “Full” mark, you need about 5.3 quarts.
