Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 10 of 10
Thread: Help! P0304 code
  1. #1
    Registered Member
    2003 Mazda Protege5
    Join Date
    May 2018
    Location
    Colorado (CO)
    Posts
    3
    Help! P0304 code
    I drive an 03 Mazda Protege5, who has given me no problems. Last night, my check engine light started to flash and my engine had no power. I quickly got the codes (thank goodness for my Bluetooth OBDII reader) and got two codes - P0421 (I knew about that one) and P0304. From what I've looked up, I'm going to replace my wires, spark plugs and ignition coils. Should I check/ clean my EGR valve as well? If anyone has pics or schematics, I'd GREATLY appreciate it!
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    Replacing your plugs, wires and coils will probably fix your problem.
    Cleaning your EGR may not be necessary.
    The Diagram Dude
  3. #3
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    Quote Originally Posted by FoxyRoxy05 View Post
    ...- P0421 (I knew about that one)
    Sounds like your pre-cat is shot.
    You could replace it or do the "non-fouler trick" to get rid of that code.
  4. #4
    Registered Member
    2003 Mazda Protege5
    Join Date
    May 2018
    Location
    Colorado (CO)
    Posts
    3
    Thank you for your advice! I replaced the plugs, wires and ignition coils, as well as clean the MAF sensor. I also cleared the codes and reset the ECU. The car seems to be running fine but it was a bit of a rough idle when I stopped at a light. Is it true the ECU might take some time to be back at 100%?
  5. #5
    Registered Member
    2003 Mazda Protege5
    Join Date
    May 2018
    Location
    Colorado (CO)
    Posts
    3
    "Non-fouler trick"? Not familiar with that one ....
  6. #6
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    ...Is it true the ECU might take some time to be back at 100%?
    Yes, it's true. The ECU needs to relearn how to idle your car.
    It takes about 100 miles with plenty of times to idle your car.
  7. #7
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    The "non-fouler trick" makes the ecu think you have a happy and healthy pre-cat, even if it's shot, or not there at all like if you have a header.
    Drilling out the first one is a PITA !!...
  8. #8
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    A new pre-cat is about $130 US ... As long as you don't live in California or New York...
  9. #9
    Comp Engineering Student Riot_Polizei's Avatar
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    361
    Quote Originally Posted by pcb View Post
    The "non-fouler trick" makes the ecu think you have a happy and healthy pre-cat, even if it's shot, or not there at all like if you have a header....
    ...Drilling out the first one is a PITA !!...
    Hey, apparently there's an easier way of doing this!
    If you follow the link in the above comment, one of the top reviews specifically mentions using this in an aftermarket header (not sure if OBX or not) to perform the non-fouler trick.
    2002 Mazda Protege5
    ■ Sunburst Yellow ■ Black Rear Valence ■ Injen Cold Air Intake ■ Racing Beat Catback Exhaust ■ Moog Front Endlinks
    ■ Megan Racing Rear Strut Tower Bar ■ Racing Beat Rear Sway Bar ■ Mazda6 Front Big Brakes ■ Foglight Deletes
    ■ OBX Short Shifter ■ OBX 4-1 Headers
    ______________________________
  10. #10
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    Quote Originally Posted by Riot_Polizei View Post
    Cool,.. I didn't know there was something like that...
Similar Threads
  1. Replies: 2
    Last Post: 09-30-2017, 02:25 PM
  2. P0302 then P0304...
    By smetzger in forum Protege5
    Last Post: 03-11-2015, 11:39 PM
  3. msp p0304
    By pablosqy in forum Mazdaspeed Protege
    Last Post: 02-13-2012, 09:41 AM
  4. P0304 Cel
    By YokiMazoku in forum Mazdaspeed3
    Last Post: 06-09-2009, 07:12 PM
  5. misfire code p0304 help please
    By Guvy in forum Protege5
    Last Post: 04-23-2007, 09:34 AM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
