In Memory of Member 1338
Results 1 to 11 of 11
Thread: '02 Protege5 burning oil, white smoke on startup/post downhill acceleration
  1. #1
    Registered Member
    Mazda Protege5
    Join Date
    Jul 2009
    Location
    Portland
    Posts
    58
    I've noticed in the last 6months to a year that my PR5 has been burning oil and smoking sometimes on a cold start after sitting for 8+ hours. This usually lasts for the first 5mins of driving then goes away. I've also noticed that when I drive downhill and use the engine compression for braking, once I accelerate after this, I'll get a big puff of white smoke, even if the car is warmed up. My coolant levels are fine, so it's nothing related to that, but I'm adding maybe 1-2 quarts a month. I'm not getting any check engine lights, but I have installed the O2 sensor trick which is popular for the PR5.
    Any suggestions where to start?
  2. #2
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Springfield, MO Area
    Posts
    977
    2002 Protege5 5 Speed, Pure White, FSZE Swap, Konig Incident 17's
    2006 Chevy Silverado 1500 4x4 5.3
  3. #3
    Registered Member
    Mazda Protege5
    Join Date
    Jul 2009
    Location
    Portland
    Posts
    58
    Quote Originally Posted by MrGiggles View Post
    Thanks for the follow up. I gather I'm looking at a serious bill for the repair or ride her 'til she croaks. 150,000 miles, decent shape, but not sure she's worth spending over $1000 in repairs. Sounds like it's not a job I'm comfortable doing.
  4. #4
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,860
    Switching to 10W30 regular dino oil can slow down the burning as well as save you some money.
    Some guys opted to replace the engine with a used one but that is still kinda expensive.
    The Diagram Dude
  5. #5
    Registered Member
    BJII Astina SP20
    Join Date
    Apr 2016
    Location
    Australia
    Posts
    207
    I have had somewhat success fixing this issue on a friends GF FSDE 626. His 626 hatch had over 300'000 km's and would blow smoke at start up, hard acceleration from lights, and he had to top up the oil every few days. He was going to dump the car and I said let's try something and see what happens. He agreed as it was a nothing to lose situation anyway. If it doesn't work the car is going to be scrapped anyway.
    We removed the old oil and put in oil designed for diesel engines only (not oil designed for diesel or petrol) and about 500ml of diesel mixed into the crankcase. He ran like that for about 50km's. We then changed the oil (was black as night) and oil filter and did the exactly the same again. Diesel only oil with 500ml diesel into crankcase with new oil filter. About 50 kms later he said it was getting better, so changed the oil and filter again but this time we put diesel oil only. Another 50 km's like that and we changed to 10W 30W normal petrol oil with new filter. The car hardly blows smoke at start up now, but a slight hint of blueish smoke when he guns it off the line every now and then.
    This was done in October last year, and he is still driving it today with hardly any smoke from the engine anymore. So it worked for him. No guarantees this will always work and is something I would hesitate do on my engine if ever the issue was to arise on my FSDE. But there yo go. He spent a few $$'s on the oil and filters yes, (almost AU$400 all up) but it did improve the engine smoking issue.
    I have read of people having success filling the crankcase entirely with diesel only - and running engine for 30 min or so, then doing oil and diesel mixture into crankcase, then finally oil only. But I was not game to try that.
  6. #6
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    324
    You may have a couple things going on. Or it may all be caused by the valve stem seals. Smoke for a minute at start-up is almost always caused by valve seals. AS the car sits overnight, the oil in the head will pool in the lowest position (valves) and seep into the combustion chamber. When you first start the car, it burns off the oil that has seeped in. Also during deceleration (engine braking) the vacuum created is increased, and sucks oil in through dried out valve stem seals. This is a pretty common problem, and while it may be inconvenient, it's not really going to hurt anything short term. long term you'll be looking at a cat converter, maybe fouled out plugs but it's not going to do any major damage. I'd bet your valve stem seals are pretty bad from the sounds of it.
    It is possible that you've got a problem with the rings, but my experience would put my money on valve seals if I were a betting man. But to be safe, I would Check compression, you can "rent" a compression tester from autozone for free.
    If compression is good, the engine has a lot of life left in it and it's probably just the oil control rings sticking, causing the smoking. This isn't uncommon to have great compression and smoke. There's 2 sets of rings on the car...
    -oil control rings - these distribute oil to the piston and cylinder wall
    -compression rings - these are what give the cylinder compression and allow the combustion process to occur.
    If compression is low, then compression rings and/or cylinder wall likely has significant wear and scoring. Best bet would be to rebuild the motor or replace it. Probably not much life left to it (I wouldn't take any long trips).
    If compression is good, then it's probably either valve seals, or the oil control rings stuck and probably sludged up. Using Diesel, ATF, or a wide variety of other detergents mixed with the oil pre-oil change is something that's been tossed around for a while. Really, the only TRUE way to de-sludge an engine is to take it apart and clean everything, replace what's worn, and put it all back together. However, it wouldn't hurt to put a quart of ATF or whatever detergent in the oil, let it idle for 30 minutes and change the oil. Maybe get a few gallons of cheap oil and repeat the process a couple times. AFter 30 min of idling it will likely come out black as night like you hadn't changed the oil in years. Keep doing this until after the 30 min it comes out looking clean, then put your good oil in and run it. (I wouldn't change your oil filter until you're ready to put in the good oil at the end)
    Also just to note, depending on how much your motor smokes it may continue to do so for a while until it burns off the caked oil out of the exhaust pipe.
  7. #7
    Swollen Member Natey's Avatar
    Donated: $40
    Mazda
    Join Date
    Jan 2003
    Location
    Pleasure Point, California
    Posts
    6,455
    Oil rings would make black smoke, no?
    White smoke = water or coolant related.
    NPOT (Norcal Protege Options Team)
    http://www.cardomain.com/ride/335883...photo-gallery/
  8. #8
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    324
    Quote Originally Posted by Natey View Post
    unless you look closely, or familiar with engines and seen the different kinds of smoke, 99% of people can't tell the difference between blue/black/white smoke. IT's just "gray" lol
    Plus he said he's using 2 qts of oil per month. And the coolant levels are fine... IF the oil was going into the coolant it would be obvious (not to mention the coolant levels would keep increasing).
  9. #9
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,860
    Quote Originally Posted by pb4ugotobed View Post
    It is possible that you've got a problem with the rings, but my experience would put my money on valve seals...
    Our specific engine has a problem with oil ring seizing.
    The link that MrGiggles posted covers it.
    There is an easy test to see of you have bad valve seals or seized oil rings.
    Let your car sit overnight, then in the morning, remove your plugs and look down the plug hole to see if the pistons are wet with oil or not.
    If they are wet then your valve seals are leaking.
    If they are dry, put your plugs back in, start your car and run it for about 20 seconds then shut it off, remove the plugs again and check for oil on the pistons.
    If they pistons are now wet with oil, then your oil rings are seized.
  10. #10
    Jeff
    2003 MP5, 2000 Audi S4, 67 Mustang (hers)
    Join Date
    Nov 2008
    Location
    Renton, WA
    Posts
    44
    I was also burning a quart or so per month...dealer had no idea (compression was fine and all the plugs looked normal) and a 2nd mechanic had no idea except he said there is a lot of gunk in there.
    So, I ran an engine flush detergent (liquimoly) in a warm engine at idle for 15 mins before changing the oil. Smoke in startup was down about 90%. And I had serious spy vs spy smokescreen before...I could fog half the neighborhood. 2 weeks later I did it again....smoke is gone and that was 3 weeks ago.
  11. #11
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,860
    Quote Originally Posted by n2stox View Post
    Kool !!!
    You're the first one I'm aware of that has fixed this problem without an engine rebuild or replacement.
    That means there is hope for the others who are burning oil, and there's a lot others.
Similar Threads
  1. Some smoke on startup
    By FlyinHawaiian in forum Mazdaspeed Protege
    Last Post: 11-07-2014, 10:05 AM
  2. Replies: 6
    Last Post: 10-03-2013, 10:05 AM
  3. White smoke...jerky acceleration...knocking noise...please help
    By papaburgundy25 in forum Mazda3 Engine & Transmission
    Last Post: 01-27-2013, 01:18 AM
  4. Burning Oil On Startup?
    By Maxx Mazda in forum Mazda How-To
    Last Post: 05-16-2007, 07:53 PM
  5. White Smoke: Burning oil (?)
    By Murda in forum Mazda How-To
    Last Post: 07-05-2005, 10:40 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
