Compare auto reliability with reliable results at TrueDelta.com!
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Holding flywheel for crankshaft bolt?
  1. #16
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    Quote Originally Posted by pb4ugotobed View Post
    To hold the pulley when putting the crank bolt back on you can use a chain wrench, always works great. I always keep a spare (junk) belt cut up for it... wrap it around the crank pulley and then put the chain wrench on it and it keeps the chain wrench from gouging into the grooves for the belt.
    Works great for removing the bolt too, but i always find it easier to rest my ratchet on the frame rail and bump the starter
    I didn't think of that... I've had one for almost 20 years, I don't think I've ever used it.
    The Diagram Dude
  2. #17
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    310
    That would work. Mine has a long handle like a breaker bar instead but same principle. just make sure to wrap an old belt or something around the pulley before setting the chain wrench up or it'll mess the belt grooves in the pulley all up.
Similar Threads
  1. Crankshaft bolt
    By Scottscott in forum Mazda3 Engine & Transmission
    Last Post: 04-16-2016, 09:16 PM
  2. Replies: 7
    Last Post: 02-06-2012, 12:37 PM
  3. Crankshaft Pulley Bolt?
    By robcuda67 in forum Miata Lounge
    Last Post: 11-14-2010, 01:11 PM
  4. Crankshaft pulley holding tool
    By wanna3 in forum Mazda3 Engine & Transmission
    Last Post: 08-12-2010, 08:56 PM
  5. 2002 Protege removing crankshaft bolt
    By cloudyinpdx in forum Mazda Protege
    Last Post: 11-28-2008, 10:35 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
