Made in USA and Free Shipping on all orders shipped inside the US.
Results 1 to 12 of 12
Thread: Protege5 Brake Upgrade
  1. #1
    Registered Member
    Mazda Protege5
    Join Date
    Jan 2018
    Location
    Garden Grove, CA
    Posts
    44
    Hello fellow Mazda friends! I want to do a bugger brake upgrade and have seen a few threads talking about mazda6 rotors and calipers working. Is this true and if it is what do I need from the mz6 to have functional brakes on my Protege5? Side note: I am running 16 rota wheels, Fitment issues? Thanks in advance!
  2. #2
    Registered Member JDM323J48's Avatar
    2002 323 protege
    Join Date
    Jul 2011
    Location
    ingham queensland
    Posts
    590
    For the fronts you need calipers, caliper brackets and rotors, the 300mm mazda6 ones work with 16" wheels.
    For the rears the msp rears will give you the same size as mazda6 but with correct E-brake setup, you'll need calipers, caliper brackets and rotors.
  3. #3
    Comp Engineering Student Riot_Polizei's Avatar
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    364
    Don't get the Mazdaspeed6 brakes, since you need 17" rims at a minimum. If you already have 17" rims, then you're all good to get the upgrade to the upgrade!
    Out of curiosity, are you getting these online, or are you pulling them from a junkyard? I wanted to buy some from rockauto, but the core charge would absolutely nuke my wallet. I'm not sure I could even send back my P5 parts when I ordered Mazda6 parts...
    2002 Mazda Protege5
    ■ Sunburst Yellow ■ Black Rear Valence ■ Injen Cold Air Intake ■ Racing Beat Catback Exhaust ■ Moog Front Endlinks
    ■ Megan Racing Rear Strut Tower Bar ■ Racing Beat Rear Sway Bar ■ Mazda6 Front Big Brakes ■ Foglight Deletes
    ■ OBX Short Shifter ■ OBX 4-1 Headers
    ______________________________
  4. #4
    Registered Member 915_P5's Avatar
    02 Mazda P5
    Join Date
    Feb 2010
    Location
    Hell Paso, TX
    Posts
    1,109
    Do you have a pull-a-part in your area, that's where i got mine for the cheap. Still have yet to do the upgrade but one day.
    MSP HEADLIGHTS, MSP DOOR SILLS, MAZDASPEED AXLE BACK, S2K ANTENNA, REAR WIPER DELETE, FRONT PLATE RELOCATOR, TEIN COILOVER/STRUT SUSPENSION, OBX HEADER 4-1 W/ FOULER TRICK, K&N DROP IN FILTER, SPORT SHIFTER BASE, FRONT LIP, DIY FOGLIGHT MOD, COMPASS/TEMP MIRROR
  5. #5
    Registered Member
    Mazda Protege5
    Join Date
    Jan 2018
    Location
    Garden Grove, CA
    Posts
    44
    Quote Originally Posted by Riot_Polizei View Post
    Yeah I pull most my parts from the local junkyards around me it’s seemed to work so far
  6. #6
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    364
    Quote Originally Posted by 915_P5 View Post
    I got a "U pull N' Pay" a little ways south, but the only Mazda6 they have there has aftermarket wheels with spline lugs all over it! I can't get the brake upgrade until I get a key for those damn lug nuts...
  7. #7
    2002 323 protege
    Join Date
    Jul 2011
    Location
    ingham queensland
    Posts
    590
    Grab the whole stub assy.
  8. #8
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    364
    Quote Originally Posted by JDM323J48 View Post
    "Stub" assembly? Not sure I understand.
    I know that I gotta grab the brackets, the calipers, rotors, etc.
  9. #9
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,554
    Someone has a brake upgrade setup in the FS section.................
    https://www.mazdas247.com/forum/show...nza-Brakes-etc
  10. #10
    2002 323 protege
    Join Date
    Jul 2011
    Location
    ingham queensland
    Posts
    590
    If you can't get wheels off at junkyard then remove 2 bolts holding hub assy to strut and remve from balljoint to take the lot, or alternatively hammer a socket on the lug nuts to remove them.
  11. #11
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    364
    That's clever, thanks for the tip!
  12. #12
    Looking for John Connor Breeegz's Avatar
    Donated: $10
    2003 Protege 5 -- 2016 Ford Expedition
    Join Date
    Apr 2005
    Location
    Edge of Sanity, TX
    Posts
    2,008
    I used the front caliper and rotor off of a 2002 Mazda 626 (2.5L V6). I bought them from Rockauto.
    ..They bolted right up.
    They are a little over an inch bigger than stock and fit inside my 17" rims.
    Now you see me, now you don't. I'm a Ninja.
    My Cardomain page My Alaska Picture Thread My Zombie Protege5 Project
Similar Threads
  1. protege5 with rx7 brake upgrade??
    By twilightprotege in forum Mazda Protege
    Last Post: 02-03-2010, 06:50 PM
  2. Protege5 Big brake upgrade? (using 626 parts)
    By ho bag in forum Mazda Protege
    Last Post: 05-23-2007, 06:44 AM
  3. Big Brake Upgrade
    Last Post: 11-23-2006, 09:23 PM
  4. E-brake adjustment after brake upgrade
    By registering in forum Protege5
    Last Post: 06-25-2004, 10:03 PM
  5. brake upgrade for FC...
    By hey_hej in forum Rotary Mazdas
    Last Post: 08-07-2003, 06:57 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
