Do you wait for the blue light to go away before shifting gears and start driving?
Also I found the fluid level were high (AT and engine) - the car was parked and idling for a few days.
Manual has a procedure to follow - but is it typical that the fluid level to be well above the the MAX level after idling?
AT was serviced at the Mazda dealership (fully flushed - also did 30 point inspection) - called them up and they told me to follow the manual procedure first - engine oil was changed by the used car dealer - I just did under 1k not realizing these.
