While it is on my mind, whenever I take off a vacuum hose off (and the car is off) I can hear the system depressurize or something. Is that normal?
...I dont see any lines that look worn or disconnected.
After an hour and more frustration I got the EGR out and it was stuck....
... The bolt I rounded off is in there as well. (turns out these fit in a 12 and 13mm so I don't know what size they truly are, a 12mm 12pt is what rounded it. I had no clue it was a 12pt but I've been using it for years)...
... I guess I shorted in my radio as it doesn't work (turns on but no buttons work and can't get an fm signal) so I'm calling crutchfield later.
Nice man! Glad you could fix up the problem(?)
Again, I swear that you're me from an alternate universe, because I too just fixed up my exhaust leak + shifter. So I guess that if something goes wrong on your car, or if something goes wrong on mine, a problem on the other's car is not far behind lmao
Sounds like a software type glitch to me.
See if there is a reset button or maybe disconnect your battery and reconnect it.
Keep in mind that when you disconnect the battery your ECU needs to relearn how to idle your car.
I can idle rough for about 100 miles.
