- '02 Mazda Protege5
I've been chasing this sound for weeks and I'm slowly zeroing in on where exactly it's coming from, but it is very elusive, intermittent, and not affecting performance at all, but it is a very noticeable noise which can't be ignored.
it's a clunking noise I can hear when I turn the wheel between 10 and 2 o'clock, when i'm parked, car running. I'll hear a similar sound when i turn left while going over bumps. Pretty sure they're related. but weirdly enough, i don't usually hear it while driving. looked under the car, nothing out of the ordinary. took the wheels off, checked if anything was loose, all was good.
checked the steering shaft by the brake pedal. the noise is definitely coming from directly behind the firewall in that area. but i'm not sure it's the rack and pinion itself; I was able to take off the dust boot and look inside with a flashlight at the spiral gear and the rack teeth and from what i saw it looked good. there is zero play in the steering. it has to be the joint connecting the rack to the steering shaft. Next I will see if i can inspect the other side of the firewall (there seems to be a rubber boot covering the linkage there) it got dark out so i'll do it another time. if anyone has a diagram of the parts that make up this linkage that would help me too.
I know what it ISN'T and that's control arm bushings/balljoints, endlinks, sway bar, tie rod ends, shocks/struts/mounts, CV axles...a lot of that is new and i have ruled them out.
if anyone has encountered this issue on their P5's and can shed some light onto wtf this is it would be helpful. Specifically, I want to make sure i'm not going to lose steering control while driving.
I posted a video of what i'm hearing: https://youtu.be/q8GpB-jA274
thanks guys, this forum is very helpful, and I'm learning a lot.
