Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 3 of 3
Thread: CV axle/boot question
  1. #1
    Registered Member
    Protege5
    Join Date
    Jan 2018
    Location
    KY
    Posts
    4
    So, I noticed a tear in my cv joint boot a while ago, and I had planned on taking it to a buddy's place this past weekend to get it replaced since he has a garage, the proper tools, and lots of experience. Unfortunately, he wasn't available this weekend so I figured that I'd be able to wit until the next. Well... I was wrong. On sunday, I noticed some noice coming form the same front driverside cv axle area and then it started making a grinding noise, but only at low speeds. I drove the car about 10 miles home and haven't drove it since.
    I talked to my friend and he said that I will probably have to replace the whole CV axle so I'm going to get the part and take it to his place and see if it just needs a new boot and grease or if it needs an entire axle. I already have a replacement boot but I need help finding the correct cv axle.
    I picked up a driver side cv axle from the AutoZone near me, but apparently, their system doesn't distinguish the Protege5 model from the regular Protege. I was wondering if they use the same part or if I need to look elsewhere.
    My protege is a 2002 Automatic
    Summary: Does the Protege5 and the regular Protege use the same cv axle on the front driver side?
  2. #2
    Registered Member
    Mazda Protege5
    Join Date
    Sep 2016
    Location
    CA
    Posts
    166
    i'd check rockauto fairly cheap, I need to do my passenger side one. I feel like they do, the one difference is between manual and automatic transmission.
    2002 Mazda Protege5 Pure White
    MP3 Flashed ECU | Mishimoto Radiator/Shroud | MS Door Sills & Shift Knob | OBX Short Shifter with CorkSport Bushings | Goodridge SS Brake Lines | CorkSport 3rd Link Mod | MPV Wiper Stalk & Tribute Nozzles | S2K Antenna | Cabin Air Filter Mod | Rear Bumper Guard with Matte Black Rear Valance | 205/55R16 Kumho Ecsta 4XII on 03 P5 Wheels
    Among the fair amount of maintenance work done.
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,532
    As mentioned, the drivers side axle is different for the automatic and standard transmission.
    Rockauto is your best bet, they're only about $30 American and you know it's going to be the right part. (I'm not sure if the regular protégé is the same)
    The Diagram Dude
Similar Threads
  1. Tie rod end boot question
    By davemsc in forum Protege5
    Last Post: 04-21-2015, 01:19 AM
  2. axle question... please help
    By 719prottege in forum Mazdaspeed Protege
    Last Post: 04-11-2011, 03:06 AM
  3. Axle question?
    By AODfan in forum Protege5
    Last Post: 11-17-2008, 12:37 PM
  4. Re:axle Boot
    By Spicymazda0323 in forum Mazdaspeed Protege
    Last Post: 04-08-2007, 05:38 PM
  5. Shift boot question
    By Autox MSP in forum Mazdaspeed Protege
    Last Post: 08-21-2004, 01:51 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
