VersaTuner - tuning software for Mazdas
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: catalyc converter california approved?
  1. #16
    Registered Member
    Mazda Protege5
    Join Date
    Sep 2016
    Location
    CA
    Posts
    166
    Quote Originally Posted by pcb View Post
    Did they look underneath your car to find it ??
    You can sorta see the second O2 sensor looking under the hood.
    It would suck for the OP if the smog guy finds his cat and he's then forced to buy the expensive CARB cat as well.
    Were they CARB compliant ??
    Yeah they did.
    Yes, they were. I had to make sure since I live in CA.
    2002 Mazda Protege5 Pure White
    MP3 Flashed ECU | Mishimoto Radiator/Shroud | MS Door Sills & Shift Knob | OBX Short Shifter with CorkSport Bushings | Goodridge SS Brake Lines | CorkSport 3rd Link Mod | MPV Wiper Stalk & Tribute Nozzles | S2K Antenna | Cabin Air Filter Mod | Rear Bumper Guard with Matte Black Rear Valance | 205/55R16 Kumho Ecsta 4XII on 03 P5 Wheels
    Among the fair amount of maintenance work done.
  2. #17
    Registered Member
    2003 Mazda Protege5
    Join Date
    Aug 2014
    Location
    Burbank CA.
    Posts
    28
    so rockauto actually shipped the cats no questions asked to california?
  3. #18
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    Quote Originally Posted by johnnyphive View Post
    Yea, but he bought the CARB compliant ones.
    The Diagram Dude
  4. #19
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    Quote Originally Posted by stormkyori View Post
    I had my smog tested after I did the non-fouler and they basically told me it was illegal ...
    There's two reasons to install the non-foulers.
    The first reason is because you installed headers and they don't have a pre-cat. The non-foulers prevent the P0421 Warm-up catalyst system efficiency below threshold.
    The second reason to do the non-foulers is when your pre-cat deteriorates, it prevents the same code.
    If stormkyori had headers when he first went for the smog test, they would have noticed as soon as they popped the hood then on further inspection they would have noticed the non-foulers.
    The non-foulers kinda stick out and attract attention.
    Then you fail your test and are told you need to buy CARB compliant cats. And,.. I'm pretty sure they would record your licence plate # and Vin # so you can't just throw on any cats and hope to go to a different smog testing place and hope to pass... They will have you on record and specifically look for CARB compliant components.
    Natey didn't attract any suspicion when they looked under his hood so they didn't bother looking under his car.
    My point being,... There is a chance the smog dudes will look under your car, then you'll still have to buy and install the CARB compliant cats after already spending the time and money on regular cats.
    So it's somewhat of a potentially expensive gamble.
    Personally, I think you should try the regular cat... It sounds like you have a really good chance of passing.
    And remember,.. You're not wrecking the earth using regular cats... Even if you have no pre-cat, the main cat will cleanup everything. (except for the first few minutes when your car is cold).
  5. #20
    Registered Member
    2003 Mazda Protege5
    Join Date
    Aug 2014
    Location
    Burbank CA.
    Posts
    28
    got one bite, out of 4 requests, waiting to see if its for sure..
  6. #21
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    You could just go for a road trip across state lines and do some shopping.
  7. #22
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,562
    I'm in TX, have header with non-foulers & running a magnaflow hi-flow cat. No codes and have never had any issue getting inspected. They do gather people around and point and look and then they come take my $3 off coupon and hand me my pass paperwork I need to go get the registration. Not that this has anything much to do with passing inspection in other states........
Similar Threads
  1. Mazda approved mod sticker?
    By schlepperock in forum Mazdaspeed3
    Last Post: 01-07-2011, 11:56 AM
  2. AMM Status (Approved Merchant Member)
    By www.03msp.com in forum Lounge
    Last Post: 03-19-2004, 12:17 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
