VersaTuner - tuning software for Mazdas
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: catalyc converter california approved?
  1. #1
    Registered Member
    2003 Mazda Protege5
    Join Date
    Aug 2014
    Location
    Burbank CA.
    Posts
    28
    Hi All,
    So my catalyc converter has fouled, looking into Ebay there's a bunch that are cheap from Canada but are not "Legal" in California, anyone know why? I'm looking into the Walker 31642 direct fit, but its over $400! cheapest was on Amazon for $314 with Gaskets but I just don't have that kind of money right now. I am in Southern California anyone know of any cheaper options? Any links, leads appreciated thanks!
  2. #2
    2008.5 MGM MS3 rsvinylgraphics's Avatar
    Donated: $5
    Join Date
    Oct 2009
    Location
    Indiana
    Posts
    1,136
    Well you can get a Walker universal cat for around $130 on Amazon however since it is not a direct fit it will require some modifications to your exhaust, what exactly needs to be done, I don't know, maybe somebody else who knows will chime in.
    http://www.walkerexhaust.com/catalog...catalog-lookup
    https://www.amazon.com/Walker-82620-.../dp/B00C5676LI
  3. #3
    Swollen Member Natey's Avatar
    Donated: $40
    Mazda
    Join Date
    Jan 2003
    Location
    Pleasure Point, California
    Posts
    6,455
    I bought one from eBay. I had to trim a little with my Dremel to make it fit onto my MSP's exhaust, but it passed smog no problem, my car sounds great, and I don't smell anything weird.
    I think that disclaimer is just a disclaimer. I'm in California and I passed fine with the eBay one.
    I bought mine from a user called "muffexpress"
    NPOT (Norcal Protege Options Team)
    http://www.cardomain.com/ride/335883...photo-gallery/
  4. #4
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    Here's another thread about California exhaust.
    If you do the work yourself, you should be able to "get away with it", they might catch something on a visual inspection.
    https://www.mazdas247.com/forum/show...erter-question
    The Diagram Dude
  5. #5
    Donated: $40
    Mazda
    Join Date
    Jan 2003
    Location
    Posts
    6,455
    I think you should definitely go with what the guy from Canada says.
    haha! just playin. I DID pass fine though, and no one climbed under my car for a visual inspection.
    Here's what I had to trim. Took all of 5 min.
    Attached Images Attached Images
  6. #6
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    Quote Originally Posted by Natey View Post
    I was under the impression that being California compliant was a BIG deal in California maybe even with criminal consequences. Same goes with the non-fouler trick.
    Here in Ontario, they just plug into the OBDII port and that's it.
    I could pass my smog test with no secondary cat at all.
    There is no code for the secondary cat and it's after the O2 sensors.
    I guess it's where you go and who you know in California and what kind of visual inspection they do.
    A lot (maybe most) companies won't ship a non CARB cat to California... I don't think they're supposed to.
    Natey managed to get it all done.
    Just do what he did and order from a place that will ship to you.
    The crappy part is that all new cats work very effectively.
    A CARB compliant cat doesn't make the air any cleaner.
  7. #7
    Donated: $40
    Mazda
    Join Date
    Jan 2003
    Location
    Posts
    6,455
    Aww man, no quoting the just playin' part? (strike)
    Anyway, my car's got 70K miles or so and has always been 100% stock and well maintained. Both cats, stock intake/exhaust, are all in place etc. I put in a new 02 sensor and replaced my old cat and my MSP passed smog inspection fine. Never messed with the pre-cat at all.
    It's basically a visual inspection (they pop the hood and poke around a little, I guess to see the intake, intercooler and whatever else looks shady) and a sniffer test.
  8. #8
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    Actually you posted that part after I posted...
    But,... I am curious as to what would have happened if you were "caught" ???
    Would you have simply not passed your e-test ?? Would you be fined ?? Would they take your car ?? Would they ship you right off to jail ??
  9. #9
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    Quote Originally Posted by pcb View Post
    I could pass my smog test with no secondary cat at all...
    This is my smog results from the last year that Ontario sniffed the tailpipes. (2011)
    The guy had a big smile on his face and said he had to do the test twice because he though his machine was broken.
    Turns out my car almost doesn't pollute at all. He said it pollutes less than when the car was brand new. He'd never seen anything like it before.
    I probably could delete my cat and still pass a sniff test.
    Too bad my car is a rusty turd worth about $300 as scrap.
    Maybe I can sell my engine to someone on the forum when my ass falls through the floorboards
  10. #10
    Registered Member
    2003 Mazda Protege5
    Join Date
    Aug 2014
    Location
    Burbank CA.
    Posts
    28
    the problem is finding a seller that is willing to ship to california. I'll contact a couple of sellers and if none of them budge I'll have to figure a work around. It seems like the cats I've seen on ebay are direct plug n play units so I might not have to do any mods. Also, the guy that I've gone to for my smog has only done a visual inspection and has never gone under the car so I think I can get away with it:
  11. #11
    Registered Member
    2003 Mazda Protege5
    Join Date
    Aug 2014
    Location
    Burbank CA.
    Posts
    28
    thanks for the input,I'm gonne look up this seller and if they refuse to ship to California I have figured out a work around to get it to me
  12. #12
    Donated: $40
    Mazda
    Join Date
    Jan 2003
    Location
    Posts
    6,455
    25,000+ transactions, 99.5% positive. I'll bet they'll tell you "off road use only", then send it to you, then I bet you'll pass smog.
    https://www.ebay.com/itm/MagnaFlow-D...ZULeR6&vxp=mtr
  13. #13
    Registered Member
    Mazda Protege5
    Join Date
    Sep 2016
    Location
    CA
    Posts
    166
    I had my smog tested after I did the non-fouler and they basically told me it was illegal and if I had any information on that. I told them it was sold to me like that. I just didn't pass. I bought both eastern catalytic converters off rockauto and been fine ever since.
    2002 Mazda Protege5 Pure White
    MP3 Flashed ECU | Mishimoto Radiator/Shroud | MS Door Sills & Shift Knob | OBX Short Shifter with CorkSport Bushings | Goodridge SS Brake Lines | CorkSport 3rd Link Mod | MPV Wiper Stalk & Tribute Nozzles | S2K Antenna | Cabin Air Filter Mod | Rear Bumper Guard with Matte Black Rear Valance | 205/55R16 Kumho Ecsta 4XII on 03 P5 Wheels
    Among the fair amount of maintenance work done.
  14. #14
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    Quote Originally Posted by stormkyori View Post
    I had my smog tested after I did the non-fouler and they basically told me it was illegal ...
    Did they look underneath your car to find it ??
    You can sorta see the second O2 sensor looking under the hood.
    It would suck for the OP if the smog guy finds his cat and he's then forced to buy the expensive CARB cat as well.
    ... I bought both eastern catalytic converters off rockauto and been fine ever since.
    Were they CARB compliant ??
  15. #15
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    Rockauto has some pretty cheap ones...
    About $170 American.
    I don't know what they would be like about shipping ??
Similar Threads
  1. Mazda approved mod sticker?
    By schlepperock in forum Mazdaspeed3
    Last Post: 01-07-2011, 11:56 AM
  2. AMM Status (Approved Merchant Member)
    By www.03msp.com in forum Lounge
    Last Post: 03-19-2004, 12:17 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
