In Memory of Member 1338
Results 1 to 4 of 4
Thread: 2001 SE Build
  1. #1
    Registered Member
    2001 Mazda Miata SE BRG
    Join Date
    Apr 2018
    Location
    Oklahoma City
    Posts
    4
    2001 SE Build
    Hello, all. I've recently purchased a miata in rough shape and I was looking for a fun project car as I'm finally at a place in my life where I can work on one. I guess I'll start at the beginning.
    I purchased the car for a good deal and took it home doing 30mph. The front wheels were pointing in different directions but somehow I made it home. It looks sharp though and already has a hardtop. Just needs some love.
  2. #2
    Registered Member
    Join Date
    Apr 2018
    Location
    Oklahoma City
    Posts
    4
    So the front wheels were pointing in 2 different directions. I drove the car to an alignment shop only to have them turn me away because my control arm bushings were shot. Had to drive back home and hope a tire didn't pop. When I made it, the metal wire had been worm through in a spot and the tire was bulging. I spent the next 2 weeks replacing upper and lower control arms. I destroyed the tie rod ends getting them out so I repacked those as well. The ball joint boots were trashed anyway so it was good to replace those as well. Between seized tie rods and control arm ball joints, I went through a few tools and broke some things. Coilovers will come eventually. For now, I just want to drive it straight down the road.
  3. #3
    Registered Member
    Join Date
    Apr 2018
    Location
    Oklahoma City
    Posts
    4
    This brings us to the current state.
    The front wheels are now much straighter. I ordered two 15X8 konig dial in wheels for now. Once those come in, I'll put some tires on them and rotate my back wheels to front, new wheels to rear so I can take it to get aligned. I'll get the other two wheels in time. Too much money at once so I've got to break it up.
    My parking brake is still in need of repair. It will engage when pulled up but not lock out. I have the release button but it's not attached. I can see a thin rod inside of it but it won't reach out enough to screw in the release. Does anyone have any experience with the handbrake assembly?
    I'm also thinking of removing the dash in order to remove the carpet so I can detail the car completely. The car is filthy in it's current state. I pulled the center console to follow some poorly ran amplifier cable and it was disgusting underneath. I'm sure removing the dash will be a nightmare but it will give me a chance to learn the car through and through. I'm trying to see the positive!
  4. #4
    Registered Member
    Join Date
    Apr 2018
    Location
    Oklahoma City
    Posts
    4
    New steering wheel went on with nrg hub and quick release. 2 wheels arrived. I'll see if I can get tires here by the weekend
Similar Threads
  1. stivine6's 2001 Mazda Protege Build
    By stivine6 in forum Mazda Protege
    Last Post: 10-11-2014, 10:26 AM
  2. Aw_MP5 - Build Thread - Slow Build
    By Aw_MP5 in forum Protege5 Builds
    Last Post: 05-13-2014, 12:45 AM
  3. EBellis Mazda3 Build (mild na build)
    By EBellis in forum Mazda3 General
    Last Post: 07-25-2012, 06:54 PM
  4. Frankjuda's 2001 protege build well kinda
    By frankjuda in forum Mazda Protege
    Last Post: 06-09-2011, 04:51 PM
  5. MS3 engine build/PTE 5557 build completed
    By Cherryvodka in forum Mazdaspeed3
    Last Post: 04-29-2010, 02:58 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
