Made in USA and Free Shipping on all orders shipped inside the US.
Results 1 to 9 of 9
Thread: Water in back
  1. #1
    Registered Member
    Protegé5
    Join Date
    Aug 2017
    Location
    Indiana
    Posts
    18
    Water in back
    I seem to have a pond of water in my spare tire well does anyone else have this or had this? If so what’s a good fix other then just draining it I don’t want a rust issue.
  2. #2
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    36
    I noticed this too. I have no idea how it's getting back there. i think there was a rubber drain plug under it and i just removed it so the water doesn't have the chance to sit there for a long time.
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,757
    Some guys found it was coming in around the rear light fixtures. They removed them and put rubber washers on the bolts and some silicone around the fixture and seal.
    I just cut a small notch in my drain plug. I didn't want that big of a hole under the spare tire.
    The Diagram Dude
  4. #4
    Swollen Member Natey's Avatar
    Donated: $20
    Mazda
    Join Date
    Jan 2003
    Location
    Pleasure Point, California
    Posts
    6,321
    It's a pretty common issue unfortunately. It's definitely coming in around the tail lights. Some people get in there and weld or epoxy it, but a lot of people do what paul did and just either pop off the drain plug (p5) or drill a tiny hole to let the water drain (Sedan/MSP).
    There's a thread around here somewhere...
    https://www.mazdas247.com/forum/show...highlight=leak
    NPOT (Norcal Protege Options Team)
    http://www.cardomain.com/ride/335883...photo-gallery/
  5. #5
    SELECT * FROM DonutBox 323's Avatar
    (-_-) ...zZzzZzZZ
    Join Date
    Mar 2007
    Location
    757
    Posts
    4,880
    i put rubber washers before putting the nuts for the tail lights back on. been over a year and my spare tire area has been dry.
    03 MSP, 03 P5
  6. #6
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,438
    Could also be body seams..........
  7. #7
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    198
    mine is dry, always has been. but my old corolla would fill the spare tire well and the sides behind the panels full of water. I just used a punch and popped a couple 1/4" holes in the bottom so it could drain and never had a problem again lol
  8. #8
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,757
    Quote Originally Posted by pb4ugotobed View Post
    ...and the sides behind the panels full of water....
    My rear corners are self draining too !!
  9. #9
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    198
    In that case... I'd recommend to the original poster to leave it alone. Eventually it appears the P5 will fix itself of those pesky water leaks!
Similar Threads
  1. Replies: 0
    Last Post: 08-09-2017, 12:38 PM
  2. Replies: 3
    Last Post: 02-17-2011, 09:58 AM
  3. Water, Water Everywhere! Time for a New Radiator!
    By kneedragger241 in forum Miata Lounge
    Last Post: 05-11-2008, 07:28 PM
  4. Replies: 4
    Last Post: 12-27-2007, 02:54 PM
  5. Diff between Corksport Cat-back and Turbo Back??
    By mattybo in forum Mazdaspeed Protege
    Last Post: 03-10-2004, 08:29 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
