In Memory of Member 1338
Results 1 to 2 of 2
Thread: Steering Wander Mazda6 GT
  1. #1
    Registered Member
    2014 Mazda6 GT
    Join Date
    Jan 2018
    Location
    Toronto
    Posts
    3
    I bought a used Mazda6 GT with 50k KMs on it 2 months ago. From the start the car had a slight steering wheel wandering problem on the highway.
    On a flat straight highway the car feels as if it is too windy outside and pushing the car either slightly left or right. I constantly adjust steering wheel back and forth a tiny bit like a boat just to stay in my lane.
    However, it is not windy what so ever. My first thought was tires. Recently I bought 4 new winter tires with 4 new steel rims. Got them balanced on a hunter road force machine and got the alignment done from Mazda dealership. To my surprise car still feels exactly the same!
    I am now suspecting something on the suspension is either worn out or needs adjustment. Has anyone here experienced something similar or is there a common suspension part that needs to be replaced often? The problem is not bad enough to start spending money diagnosing it at dealerships. It is just annoying.
    Can there be a positive or negative camber even after an alignment?
  2. #2
    Registered Member concept's Avatar
    2014 Mazda3 S GT auto, 2008 MX5 6-speed
    Join Date
    Mar 2009
    Location
    San Diego
    Posts
    1,621
    A good alignment shop's techs typically know suspension components and can spot worn-out parts or loose hardware. I recommend that you take your car to such a shop, especially if you do not know the maintenance/repair history of the car. Another possibility is a bad wheel bearing, although noise during cornering often reveals this type of issue.
    2014 3S GT, Deep Crystal Blue, Eibach Pro-Kit, Enkei PF01s, Koni Sports, Pirelli P ZERO ALL SEASON PLUS tires, 225/45/18
    2008 MX-5 Touring (Mazdaspeed CAI, HIDs, Progress/Koni Sports/Racing Beat sways, SST Magnaflow muffler and tips)
Similar Threads
  1. 2014 Mazda6 steering column shroud vibration
    By kl2n in forum Mazda6 General
    Last Post: 07-27-2014, 11:45 AM
  2. 2003 Mazda6 S and 2004 Mazda6 S help!
    By EasyCar in forum Mazda6 Engine & Transmission
    Last Post: 06-05-2012, 11:01 AM
  3. Car likes to wander...
    By spec2speed in forum Mazda6 Wheels, Tires, Brakes & Suspension
    Last Post: 11-24-2010, 03:47 PM
  4. Adding Mazda6 Illuminated Door Sills to 2009 mazda6
    By RaVE_Noodles in forum Mazda6 Accessories & Appearance
    Last Post: 08-04-2009, 11:36 AM
  5. Front-End Wander, Launch Solutions
    By REZXPERT in forum Mazdaspeed3
    Last Post: 08-22-2007, 09:56 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
