VersaTuner - tuning software for Mazdas
Results 1 to 3 of 3
Thread: Replacing Right Front Engine Mount
  1. #1
    Registered Member
    02 Protege LX, 03 P5 (x2), 09 Miata, 07 Mazda3, 13 Fit, 09 Ody
    Join Date
    Aug 2013
    Location
    MD
    Posts
    70
    So, need to replace the right front motor mount on my automatic. Looks pretty easy.
    Q: Where do I place the jack to hold the motor up? I was thinking of putting a small 2x4 under the oil pan and then jacking up from there. Is that the best place?
    Thanks,
    13 Fit | 09 Ody | 09 Miata | 07 Mazda 3 | 03 Protege5 | 02 Protege
  2. #2
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Springfield, MO Area
    Posts
    969
    Quote Originally Posted by smetzger View Post
    Thanks,
    Yep.
    2002 Protege5 5 Speed, Pure White, FSZE Swap, Konig Incident 17's
    2006 Chevy Silverado 1500 4x4 5.3
  3. #3
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    252
    thats what I do. you won't have to "jack" it much, just an inch (if even that far) to take the weight off the motor mount and allow you to swap it.
    If that one is torn, however, check the bottom one in the front. I can guarantee that one is broken as well.
    You can change both of them in under 10 minutes. Because they're so quick/easy to change I just got the cheapest ones I could find on Amazon and they worked great. If they were a pain to change like the rear mount, i'd probably get a better quality but something that takes less time to change than it takes to change the oil I don't really care if I have to replace them every 30k miles. But i've got at least 30k on them now and no issues at all.
    just take note the top right mount (the one over the belts) is different between auto trans and manual trans so make sure you get the right one.
Similar Threads
  1. Replies: 9
    Last Post: 02-20-2014, 02:11 AM
  2. need a front engine mount and rear trans mount
    By Billy23 in forum Mazda6 Engine & Transmission
    Last Post: 01-04-2011, 11:58 PM
  3. WTB: mazda protege Front Engine Mount 2.0L engine
    By pdodson311 in forum Completed Transactions
    Last Post: 11-21-2009, 05:13 PM
  4. ~*SU Front Engine Mount*~
    By mazdaspeed777 in forum Completed Transactions
    Last Post: 12-29-2008, 11:43 PM
  5. AWR Front Engine Mount
    By rizzo in forum Mazdaspeed Protege
    Last Post: 04-16-2005, 02:45 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
