In Memory of Member 1338
Results 1 to 3 of 3
Thread: Adding a fog light switch to a sport not using the combination OEM
  1. #1
    Registered Member maykelcj's Avatar
    2010 Mazda 5, 91 BRG Miata
    Join Date
    Aug 2014
    Location
    United States
    Posts
    56
    Question Adding a fog light switch to a sport not using the combination OEM
    I'm trying to add some aftermarket fog lights and I can tap into the harness for the lights by the bumper harness. My problem is I don't want to spend close to $100 on a OEM combination switch when I have a few regular switches that fit perfectly on the left blank spaces. I have tried to figure out which wires to bring in from the column to the switch and I have had no luck with it yet. Does anyone knows which wires are the ones that activate the relay for the fogs? Does it need to be connected with additional wires? Thank you!
  2. #2
    Registered Member
    2010 Mazda 5
    Join Date
    Mar 2011
    Location
    Arkansas
    Posts
    100
    You can get a switch from other Mazda's, protege is what I used, that will fit in the blanks to the left of the wheel.
    Then you will need a wiring diagram to know what wires to tap in the steering column.
    I used the switch for my after market auto lamps. I have an extra for fog lights when I decide what I want.
    2018 CX-9 Grand Touring
    2010 Mazda5 Sport Manual
    2005 Ford Freestyle Limited AWD
    2000 Ford Excursion Limited 4WD 7.3 PSD
    1991 Miata
  3. #3
    Registered Member
    2010 Mazda 5
    Join Date
    Mar 2011
    Location
    Arkansas
    Posts
    100
    The wiring diagram can be downloaded from a few places as part of a Mazda manual.
Similar Threads
  1. Replies: 1
    Last Post: 06-19-2018, 11:56 PM
  2. 2016.5 LED Combination Light
    By sbkim in forum CX-5 General
    Last Post: 02-14-2016, 09:17 AM
  3. Fog Light Switch/Illumination switch Removal
    By newUser08 in forum Protege5
    Last Post: 05-06-2015, 05:09 PM
  4. Free dimmer switch and broken fog light switch
    By Rusty Buns in forum Completed Transactions
    Last Post: 04-30-2014, 08:21 PM
  5. is back-up light switch same as 'neutral safety switch'?
    By Patrickenator in forum Mazdaspeed Protege
    Last Post: 07-01-2011, 10:43 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
