It should fit, but fit doesn't mean it would meet the specufication of an oil filter required by SkyActiv-G engines. Officially Wix 57002 is the only aftermarket oil filter meeting the specification of an oil filter for SkyActiv-G engines. Go get a Mazda OEM oil filter it's not expensive anyway.
"Standard" Mazda OEM oil filters PE01-14-302A from Japan and 1WPE-14-302 from Thailand are outsourced and made by Tokyo Roki Co., Ltd., and “Value Products” PE01-14-302A-MV is made by an unknown company in Mexico.Bosch Steel Tech oil fitlers are top notch filters. Very highly rated. I don't see HOW or WHY they would not meet Mazda specs. Made in the USA
UPDATE:
Just spoke to Bosch tech support and they said the ST3300 does fit the 2017 and 2018 CX5's. It's just that they have not updated their computer system but the ST3300 is an exact fit for the 2017 & 2018.
I believe the Mazda oil filters are outsourced and a company in Taiwan makes them? Last I checked...
I really don't get this one. I have a $3,000 engine but, spend time tying to source a cheaper than OEM oil filter, even going to the extreme of using a filter that doesn't meet specs in the written material. For less than $8.00 I can chose from OEM, Fram Ultra or NAPA Gold that will last the maximum oil filter change of 7,500 miles. Ed
I just don't want to buy a "valued" Mazda oil filter at the Mazda dealership because they are outsourced Mexico filters.
Looks racist to me, but who cares where they are made? It's mazda genuine, doesn't void the warranty and used by the dealership, can't really go wrong. As long as you change your filter every 10k, any filter is good. We use $AUD 5 filters in our workshop, on all cars, never got any problems or complaints.
Build quality sucks on the MV. Sometimes the oil filter wrench will fit, sometimes it won't. My dealer actually stocks the Taiwan filters and MV. You have to ask for the "better" one.
I think you mean Thailand, not Taiwan?
Personally if I am going to run a 10k oil change interval I would not use a cheap filter. BITOG has a section on oil filters and poster doing cut open and posting pics. Some of those filters look horrible. Many have torn filter media.
Might want to check some dealers in the area, mine sells them for 6 and some change...no shipping costs.
SkyActiv-G's require special "high-flow" oil filter hence Mazda featured different OEM filter PE01-14-302 to begin with although there's Mazda OEM B6Y1-14-302 oil filter which will fit SA-G's perfectly. But Mazda North American Operations issued a warning to their US Mazda dealers making sure not to use B6Y1-14-302 as it has different internal structure.My Mazda dealer ONLY sells the "valued" Mazda oil filters and installs them on all Mazda's. This "Mazda value" oil filter is made in Mexico and nobody knows what specs it has.
I never said I want a "cheaper" oil filter than OEM. I actually want a BETTER oil filter than OEM. If I have to spend $20, I will do it. I just don't want to buy a "valued" Mazda oil filter at the Mazda dealership because they are outsourced Mexico filters.
The Bosch ST3300 is made in Bridgeview, IL - USA
Also, please show me WHERE the Bosch oil filter doesn't meet specs in the written material?
Here is one MNAO PDF to their US Mazda Dealers concerning genuine Oil Filter(s) installation and use for ALL SA Engines..
Mazda Dealers (in USA particularly) are also seeing stored DTC's (Diagnostic Trouble Codes in PCM) when they use even 'other' genuine Mazda oil filters in Skyactiv engines, see pic, they look identical, but it is what is inside.
