Made in USA and Free Shipping on all orders shipped inside the US.
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 46 to 60 of 84
Thread: MZDA WLF Protegé5 "build"
  1. #46
    Registered Member Anzi's Avatar
    2002 Protegé5 manual
    Join Date
    Feb 2018
    Location
    SF Bay Area, California
    Posts
    127
    Got the Depo headlights off the white car, reinstalled the originals on that car, and put the projectors in the Depos, which are now on the black car. I think it looks sweet, and the HIDs certainly work great when behind super clear lenses.
  2. #47
    Join Date
    Feb 2018
    Location
    Posts
    127
    Seafoam, new spark plugs, and fresh motor oil have everything working wonderfully now. Definitely more peppy than before!
  3. #48
    31N007 KingOfSpades007's Avatar
    Mazda Protegé5
    Join Date
    Dec 2011
    Location
    Canton, MI
    Posts
    699
    Over here from Reddit (was curious to the happenings of the white car)
    Out of curiosity, did you end up keeping the motor from the white one, or did that go with the car when it was finally let go? Have you had any other engine woes on the black one??
    I LOVE how the HIDs look in P5 housings. I've got a set in mine and since the projectors are bixenon, I've got high beams from those as well as the factory halogen highs. Nighttime turns to daytime pretty quickly
    Hope the car has been treating ya well!!
  4. #49
    Join Date
    Feb 2018
    Location
    Posts
    127
    Quote Originally Posted by KingOfSpades007 View Post
    I technically still have the white car hahaha, but the black car has been behaving fine! Recently dropped the oil pan to seal it better, as it was leaking badly.
  5. #50
    Join Date
    Feb 2018
    Location
    Posts
    127
    Well, I swapped in the center console and cupholders from my *03 today. My girlfriend and I have been eating fast food lately, and having a better-functioning cupholder became more appealing.
  6. #51
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,899
    Quote Originally Posted by Anzi View Post
    Seafoam, new spark plugs,...
    How did the seafoam work out for you ?
    There's been a bit of a controversy over it lately.
    I put half a can in with my new oil every oil change (3000 Miles) and a shot in the gas every fill up.
    It's been working good for me.
    The Diagram Dude
  7. #52
    Join Date
    Feb 2018
    Location
    Posts
    127
    Sea foam seems to have done good work on every vehicle I*ve owned.
  8. #53
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,899
    The only bad thing I've heard about it on this forum was when one guys' car backfired and blew the air intake onto the driveway.
    (it wasn't a P5 though)
    He said it was worth it for the entertainment value.
  9. #54
    Join Date
    Feb 2018
    Location
    Posts
    127
    Quote Originally Posted by pcb View Post
    That*s WILD, dude. Sounds like there may have been some other issues. I use the spray stuff that uses a straw before the TB, and it seems to do a great job.
  10. #55
    Join Date
    Feb 2018
    Location
    Posts
    127
    Snapped an engine mount today while driving local backroads with a group of other car people. The PO had left one of the mounting bolts out of it (damaged threads in the hole), which probably led to metal fatigue. So I installed a new one, put the right bolt in the hole that was previously empty, and bam, problem solved.
  11. #56
    Join Date
    Feb 2018
    Location
    Posts
    127
    Okay so time for an update about my car:
    I*ve stopped ignoring all my oil loss and re-sealed both the oil pan and the valve cover, both of which were leaking a bit. Also I*m in the process of flushing out the engine to get rid of the sludge in my oil rings, as it*s been burning a decent amount of oil too. So far, ive done one flush using Liqui-Moly 2037, and intend to do another in a week (I*m running cheap synthetic and a cheap filter in the interim). After the first flush, I*m noticing the car starts easier, runs quieter, and smokes less (I expect some smoke while what is still in the exhaust burns off). So in a week, I*ll do it again, and start running Idemitsu Zepro 5W-30, which some friends have recommended to me for the type of use my engine sees. At 200k miles, I*m gonna do a third flush just cause.
    Also I got stickier tires now, they make for much fun on the mountain roads around here.
  12. #57
    Join Date
    Feb 2018
    Location
    Posts
    127
    Just did CorkSport shift bushings. Feels a little tighter than I*d like, but significantly less play in the shifter so it*s a win.
  13. #58
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,161
    ah i know which p5 this is from the fb groups now. hehe. i had asked about the product and process you used for flushing on your post. did the oil turn out extra dark when you did your flush? i have a bit of consumption too and go through about 2 quarts between oil changes. some say this is acceptable for a high mileage engine lol.
    03 MSP, 03 P5
  14. #59
    Join Date
    Feb 2018
    Location
    Posts
    127
    Yes it did turn very dark. I noticed some smoke this morning, but it was pretty white and could easily have been either condensation (was 50°f and foggy), or some leftover ATF that didn*t completely burn off yesterday when I poured some down the spark plug tubes to let it soak in and clean up the tops of the piston rings
  15. #60
    Join Date
    Feb 2018
    Location
    Posts
    127
    was doing some runs on the local touge and I broke my gearbox. It*s stuck in fourth. I*m gonna swap in the trans from the white car soon.
Similar Threads
  1. Fishdonotbounce's 2008.5 CWP Speed3 GT "Build" Thread
    By fishdonotbounce in forum Mazdaspeed3
    Last Post: 06-12-2013, 03:08 PM
  2. o0n8's Super Slow "Build" Thread
    By o0n8 in forum Pics & Builds
    Last Post: 01-15-2013, 01:35 AM
  3. Camp-Bell: "Big Bird" PR5 Build Thread
    By Camp-Bell in forum Protege5
    Last Post: 08-26-2012, 02:52 PM
  4. FS: Garrett "Disco Potato" GT2860RS TURBO For Your Build!
    By Metallic36 in forum Completed Transactions
    Last Post: 10-27-2009, 02:45 PM
  5. WTB: "Mazda" and "Protege5" Badges
    By meinp5 in forum Completed Transactions
    Last Post: 06-29-2006, 03:46 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
