- 2017 CX-5 GT AWD
@Mindless, nice job!
And easy enough to put back to stock if you ever have too.
I LOVE THAT. OMG I wish I lived close to you. I'd pay you to do that in my car.
GREAT job.
Yes but I’d be leaving a hole in the dash
It was $8. I can't think of a reason to remove it.
At first I was going to ask how the heck you were getting 24 volts on your CX-5! Then I read closely that they were only the mockups... (coffee)
I like the finished result. Thanks for sharing!
Originally I thought you could do something similar to this Japanese CX-5:So I took the plunge and I install the voltmeter today I ended up installing it on the panel with the Blindspot monitoring and the tire pressure monitoring buttons like I showed in mock up option one earlier in this thread.
That empty space is reserved for manual headlight vertical adjustment in certain countries such as France:⋯ but luckily because there’s no buttons on that side it was pretty much just empty space.
Have you ever thought about soldering these 2 wires to terminals? That should be a much better way I believe.⋯ Originally I used gonna use wire connectors to connect to the terminals on the voltmeter but they took up too much space inside that little module box so I had to just wire them directly to the tabs and put some electrical tape keep them secured.
View attachment 218747View attachment 218748
If you want remove the voltmeter when you're ready to sell your CX-5, you can always get a new panel (hopefully you can get just the cover without buttons) from Mazda dealer to replace the one with a hole.
You can't buy just the panel/cover. It comes as a whole switch assembly which runs around $100.
