Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 12 of 12
Thread: Racing Beat Rear Swaybar Questions
  1. #1
    Comp Engineering Student Riot_Polizei's Avatar
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    263
    Hey guys, I need to get a few things cleared up before I empty my wallet. I did search for some definitive answers, but didn't get any.
    I know that the RB rear swaybar will not fit a P5 on stock endlinks, and as a result, you have to buy adjustable/ES endlinks (the non-"sport suspension" ones).
    Here's the confusion: Do you absolutely need the AWR rear swaybar brackets?
    If so, which one?
    Designated for the P5, but the RB swaybar on a P5 needs ES endlinks: http://store.awrracing.com/sway-bar-...s-replacement/
    Designated for MP3/MSP/ES, but if I need ES endlinks, shouldn't this work?: http://store.awrracing.com/sway-bar-...s-replacement/
    I feel like looking up this info and reading the responses to the how-to thread (https://www.mazdas247.com/forum/show...y-bar-on-P5-ES) left me a little uncertain of myself.
  2. #2
    Registered Member
    Mazda Protege5
    Join Date
    Sep 2016
    Location
    CA
    Posts
    156
    Is that just for the RB sway bar? Otherwise i'll just get another brand if that's the case. I recently changed all 4 endlinks so I don't feel like getting new ones.
  3. #3
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    263
    Yes, just for the RB sway bar. I already own it, and it's just been sitting around, waiting for me to get my car set up for it.
    I'm unsure about whether or not I need the brackets, and if I do need them, which ones would fit.
  4. #4
    Registered Member
    Mazda Protege5
    Join Date
    Sep 2016
    Location
    CA
    Posts
    156
    Quote Originally Posted by Riot_Polizei View Post
    Oh ok cool then I'll snag a different one lol
  5. #5
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    263
    Hold on man, would you know whether or not I need brackets?
    I'm looking for answers here.
  6. #6
    Registered Member o.g.sk8er's Avatar
    Join Date
    Jul 2002
    Location
    los angeles, ca
    Posts
    1,541
    Here's the confusion: Do you absolutely need the AWR rear swaybar brackets?.
    No you don't. You can get away with using Energy Suspension bushings and brackets. When I installed mine years back, I used the 19mm ones from Energy. The reason is, they only have sizes 20.5mm or 19mm. I tried the 20.5 but was a bit too loose. The 19mm worked just fine. However, you will have to bend them to fit as they are flat from Energy. Also Kingfab6 has these pre-bent but their website seems to have been hacked or something so no link. Try and call them if you want.
    Some old crappy pics for ya.
    02 Protege 5
    Suspension:
    BC Coilovers; AWR endlinks; GT Spec front 4 point ladder bar; GT Spec rear V-Brace; GT Spec reinforcement panel; GT Spec rear strut bar; AWR trailing arms; Modded factory rear sway bar.
    Performance:
    MP3 ECU (not flashed); Unorthodox Underdrive Pulley; JDM MS flywheel (16lbs); Stock Air Box Mod with K&N drop in panel filter; 1sty Grounding Kit; TB Coolant Bypass Mod; 03 MSP Rear Axleback
    Interior:
    Kartboy Short Shifter with Kartboy Bushings; DGM CF Gauge Bezel; DGM CF passenger side dash cover; Wink 5 Panel Mirror; CF Shiftknob; Red Accent Lights; Super Bright LED's in the Gauge Cluster.
  7. #7
    Registered Member
    Mazda Protege5
    Join Date
    Sep 2016
    Location
    CA
    Posts
    156
    No, sorry. Which is why I haven't purchased a sway bar and having other things needing replacement on the car. I understand, I'm also looking for answers since ill be doing the same thing at some point.
  8. #8
    Certified Mazda Tech hornsfan10609's Avatar
    2003.5 Mazdaspeed Protege x2
    Join Date
    Jun 2009
    Location
    Austin, Tx
    Posts
    8,123
    The MSP/MP3 racing beat brackets will fit the stock subframe, but it is best to swap the reinforced MSP subframe when you do the bar.
    Mod List. "Jinba Ittai"
    2003.5 Titanium Mazdaspeed Protege #1345 Purchased 7/20/10
    2003.5 Titanium Mazdaspeed Protege #1574 Purchased 10/25/14
    2009 Highland Green Mustang Bullitt #5998 12.9@110
    2002 Red Protege5 RIP:4/25/10
  9. #9
    Registered Member
    BJII Astina SP20
    Join Date
    Apr 2016
    Location
    Australia
    Posts
    188
    hornsfan, what (or where) exactly is the difference in the subframe? Can the P5 subframe be modified to MSP spec?
  10. #10
    Join Date
    Jun 2009
    Location
    Austin, Tx
    Posts
    8,123
    There is an extra piece of metal welded into the subframe where the swaybar brackets bolt on. I think that is the only difference. In all honesty the stock subframe will probably be fine, but I swapped the whole thing when I did my RB rear bar.
  11. #11
    Registered Member
    BJII Astina SP20
    Join Date
    Apr 2016
    Location
    Australia
    Posts
    188
    Thanks. Found a pic of the differences.
  12. #12
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    263
    Ah, thanks a lot sk8r! That definitely points me in a direction, for sure. I woud've replied earlier, but man I've been ravaged by a nasty flu.
    Ultimately, I'll buy some ES Moog endlinks and test fit my sway bar. I practically have everything minus the white lithium grease, so I'll be able to get some results soon.
    Who knows, maybe I'll make an addendum to the swaybar how-to guide I linked here.
Similar Threads
  1. Replies: 0
    Last Post: 07-06-2013, 05:25 AM
  2. WTB: Racing Beat/AWR Rear Swaybar.
    By eniN6 in forum Mazda Protege For Sale
    Last Post: 04-12-2011, 09:12 AM
  3. FS Racing Beat rear Swaybar
    By dsmdizzle in forum Mazda Protege For Sale
    Last Post: 04-09-2011, 07:33 PM
  4. WTB: Rear Racing Beat Swaybar
    By Levesque in forum Completed Transactions
    Last Post: 02-10-2009, 12:28 AM
  5. WTB Racing Beat Rear Swaybar
    By Black_Protege_5 in forum Completed Transactions
    Last Post: 09-20-2006, 01:43 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
