VersaTuner - tuning software for Mazdas
Results 1 to 3 of 3
Thread: Protege5 FS-ZE Swap Crank No Start
  1. #1
    Registered Member
    Mazda Protege5 2003 Hatchback
    Join Date
    Feb 2018
    Location
    GA
    Posts
    1
    Hi guys I am new to the forums.
    I have a question for you all and hope you guys might have the answer.
    I have a 2003 Mazda Protege5 Hatchback and the original motor which is the FS-DE locked up because of an oil leak. So we swapped it out with a FS-ZE. From there we swapped out the harmonic balancer and air intake cam and starter. Now the issue is it wont start. The engine is turning good. But we did a little more research into it and it has no spark. So now we replaced the crankshaft sensor and cam sensor but still no spark. Do you guys know what the issue might be?
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,906
    Check your connectors. I remember someone here on the forum had two connectors swapped and had crank no start. (I forget which two but you can plug them in wrong).
    The Diagram Dude
  3. #3
    Certified Mazda Tech hornsfan10609's Avatar
    2003.5 Mazdaspeed Protege x2
    Join Date
    Jun 2009
    Location
    Austin, Tx
    Posts
    8,123
    Probably the neutral switch and reverse switch. Any blown fuses? Did you swap the cam gears? I know you have to with the 626, may be alright with the ZE.
    Mod List. "Jinba Ittai"
    2003.5 Titanium Mazdaspeed Protege #1345 Purchased 7/20/10
    2003.5 Titanium Mazdaspeed Protege #1574 Purchased 10/25/14
    2009 Highland Green Mustang Bullitt #5998 12.9@110
    2002 Red Protege5 RIP:4/25/10
Similar Threads
  1. 02 PR5 Crank, No Start
    By PR5Zach in forum Protege5
    Last Post: 06-16-2018, 05:04 PM
  2. Crank but no start
    By reynoldsrobbie in forum Protege5
    Last Post: 10-24-2012, 06:22 PM
  3. Will crank, no start.
    By Krazykaveman in forum Mazda Protege
    Last Post: 03-22-2010, 01:29 AM
  4. Cold start at 32F, no crank 1st/2nd attempt but start?
    By Marik123 in forum Mazda Protege
    Last Post: 01-03-2010, 10:24 AM
  5. 626 will crank, but not start
    By jalbao in forum Other Mazdas
    Last Post: 04-27-2008, 10:57 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
