Help identify broken hose - system too lean
fiercenomad
2007 Mazda 3s
Please see: imgur.com/a/qVqFP
The hose outlined in green in the above image broke, approximately at the red line on the corresponding hose on the right.
This caused a 'system too lean' code, however by taping it the code cleared.
Would like to do a more legitimate fix, however I cannot identify the part.
Is it reasonable to replace this hose and could someone point me to the OEM part or a feasible replacement part?
Much appreciated
well, since the hose is cracked near the very end of the hose, can you just cut off the cracked part and reattach? the hose looks like it might be long enough to reach if you cut off a little.
If that part number is specifically for your year, model, and trim level, then I'd say it is correct. The image is not geometrically correct but often, that is the case.
