CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 3 of 3
Thread: Sway bar endlink recommendations
  1. #1
    Registered Member
    2003 Protegé5 manual
    Join Date
    Feb 2018
    Location
    SF Bay Area, California
    Posts
    2
    Hey all, I just joined the Mazda family a week ago, bought a 2003 Protegé5. It needs rear end links, and I'm not sure if I should just get the Moog ones, or if there's a stronger option, similar to how people use the Escape/Tribute front endlinks. I also am unsure as to which size to get for stock P5 suspension.
  2. #2
    Registered Member Riot_Polizei's Avatar
    Mazda Protege5 2002
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    34
    From what I was told, Moog makes some nice rear endlinks. They're slightly beefier than OEM, if I recall correctly.
    But I gotta tell you that I've been hunting around for tougher/adjustable endlinks and have found nothing. Racingline is (or has been) out of stock and AWR no longer sells any. In that regard, we're SOL.
    However, I'd ask user Jackie Chan (https://www.mazdas247.com/forum/memb...09-Jackie-chan) about his Whiteline Swaybar links. He told me on my build page that you can cut these down to your car's spec, so perhaps he has something you'd be interested in.
    In regards to size:
    The shorter ones (I think 7.5", could be wrong) are on the P5, and the longer ones are on the ES. The P5 endlinks are referred to as "Sport Suspension". If you want to fit a thicker swaybar on your car, such as the racing beat bar, you're going to need the longer ES endlinks.
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,608
    I personally like the Moog end links (although that's not what's on my car),... They're beefier and come with grease nipples so you can keep them lubed.
    Unfortunately,.. Others describe them as overpriced hyped up crap...
    I dunno ??
    You could just build your own !!!
    https://www.mazdas247.com/forum/show...light=mcmaster
    The Diagram Dude
Similar Threads
  1. Sway Bar Endlink ?'s
    By azuelke in forum Protege5
    Last Post: 10-12-2010, 01:28 AM
  2. wtb sway bar endlink(s)
    By Protege_MP3_506 in forum Completed Transactions
    Last Post: 06-15-2010, 06:29 PM
  3. What to do about this? (sway bar endlink)
    By AutoEuphoria in forum Mazdaspeed3
    Last Post: 05-08-2010, 07:22 PM
  4. sway bar/endlink question
    By gudzspeed3 in forum Mazdaspeed3
    Last Post: 03-04-2010, 01:37 PM
  5. WTB: Front Sway Bar endlink
    By Focuz_Freek_XxX in forum Completed Transactions
    Last Post: 05-11-2005, 12:23 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
