Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 7 of 7
Thread: wheel help!
  1. #1
    Registered Member
    2003 Mazda Protege 5
    Join Date
    Sep 2017
    Location
    Ogden, Utah
    Posts
    12
    wheel help!
    i really want to know the wheel specs on my 03 MP5 like the bolt pattern or what offset would fit well and other stuff because i am at a conmplete lost
  2. #2
    2008.5 MGM MS3 rsvinylgraphics's Avatar
    Donated: $5
    Join Date
    Oct 2009
    Location
    Indiana
    Posts
    1,040
  3. #3
    long time mazda owner d0sitmatr's Avatar
    2003 Protege5
    Join Date
    Jun 2011
    Location
    Sebring, Florida, United States
    Posts
    213
    bolt pattern: 5 x 4.5 or 5 x 114.3
    stock rim size: 16 inches diameter x 7 inch width offset +45mm
    stock tire size: 195-50/16
    Ive been running 17's with an offset of +42mm on my car car with perelli p6 @ 205-50-17 without rubbing, but it should be said the perelli diameter is not as much as many other tires (the 205 50's diameter almost matched a set of bridgestones I was considering that were 205-45)
    the tires/rims that came with my car was 17x7jj off a mazda millenium running 225 45 17 tires with no rubbing on the frame, but, they did end up rubbing against the strut mounts in the rear, this could have been avoided with simple 3mm spacers, I just didnt catch it in time to save the rear tires :/
    ive read people have run 18's on the mp5, with 35 low pro tires, but personally I dont like how it looks on our cars.
  4. #4
    Registered Member
    Join Date
    Sep 2017
    Location
    Ogden, Utah
    Posts
    12
    what would good specs be if I wanted to keep running 16 wheels like what would agood offset be and the width of the rims and wheels?
  5. #5
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Springfield, MO Area
    Posts
    961
    Quote Originally Posted by ehernandez View Post
    The same as your stock wheels, posted above.
  6. #6
    2003 Protege5
    Join Date
    Jun 2011
    Location
    Posts
    213
    what would good specs be if I wanted to keep running 16” wheels like what would agood offset be and the width of the rims and wheels?
    at the moment, Im using my wifes 16" rims off her 06 Altima because my tires were in much better shape and I wanted to make sure she was safe while driving, especially with our son.
    the tires on these rims are 205/55 16, and I get a little rubbing against the fender. it should be said though, the tires are well worn (as in should have been replaced a 1,000 miles ago...) but since my car wasnt/isnt actually running atm, its no big deal.
    Ive done a little research and it would be possible to run 215/50 16 on stock rims, and 225/45 16, but I wouldnt recommend any wider than that as you will risk rubbing against struts/springs, unless you use a spacer.
  7. #7
    Registered Member
    BJII Astina SP20
    Join Date
    Apr 2016
    Location
    Australia
    Posts
    178
    Quote Originally Posted by d0sitmatr View Post
    That's incorrect. Stock alloy wheels are 6" with +50 offset.
    Bolt pattern = 5 x 114.4mm
    Diameter = 16"
    Width = 6"
    Offset = +50
    Centre bore = 67.1 mm
    Thread Size = M12 x 1.5
    Tyre = 195/50 R16
Similar Threads
  1. Replies: 5
    Last Post: 08-15-2013, 11:03 AM
  2. Replies: 5
    Last Post: 12-07-2012, 02:54 PM
  3. Replies: 8
    Last Post: 01-13-2012, 02:24 PM
  4. Replies: 7
    Last Post: 08-30-2011, 09:48 PM
  5. Front wheel drive staggered wheel fitment?
    By tsunami in forum Off Topic
    Last Post: 09-15-2005, 01:22 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
