VersaTuner - tuning software for Mazdas
Results 1 to 5 of 5
Thread: PCB I need front brake manual info please
  1. #1
    Registered Member Pmazda5's Avatar
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Richmond Hill,ON,Canada
    Posts
    113
    Smile PCB I need front brake manual info please
    I took my brake apart ,it was stuck became super hot, hope didn't warp something, but suspect piston ring problem ,not sure if rust or bad seal.Would like the manual if possible. Thanks Alex P.S. Hope you are well, see your name everywhere here.
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,170
    The Diagram Dude
  3. #3
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Posts
    113
    maybe I can ask a question about the rubber piston ring is there a right way and wrong way to install it ,is there an inside and outside way of installing it ???? Also is there a good lubricant I can use all the ones I have tried seem to gum up on me ,not sure if its the lube or if its getting contaminated ,it seems to go hard on me. Ive never had so much trouble with brakes as this car ,can anyone identify with me .
  4. #4
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,170
    I've never actually rebuilt a caliper. I did take apart a rear one from my parts car to see what makes it tick.
    The book shows a Specialty Shop Tool to remove the piston seal but it just looks like a dental pick.
    The seal sits in a groove in the caliper bore,... It's not attached to the piston.
    Make sure you use rubber grease.
    Somebody posted a grease he had good luck with... It lasts much longer but I forget what it's called... "silglide" rings a bell ??
    https://www.mazdas247.com/forum/show...ion&highlight=
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,170
    Quote Originally Posted by Pmazda5 View Post
    I took my brake apart ,it was stuck became super hot, hope didn't warp something, but suspect piston ring problem ,..
    That's usually caused by the guide pins drying up and getting sticky although the piston can rust up and seize as well.
Similar Threads
  1. Looking at the 2.0 2016 Manual Transmission info please
    By silverevo05 in forum CX-5 Lounge
    Last Post: 07-03-2015, 02:42 PM
  2. Brake Upgrade DIY/info for the 3 gen 1.6LX 4x100 lug
    By biknman in forum Mazda Protege
    Last Post: 07-14-2008, 09:33 PM
  3. info's on RX7 94-95 front brakes info pls!!!
    By Speed3.5 in forum Rotary Mazdas
    Last Post: 01-05-2008, 01:22 PM
  4. Brake info for everybody!
    By Speedplease in forum Mazdaspeed Protege
    Last Post: 08-24-2004, 11:21 AM
  5. brake info
    By jonbig in forum Mazdaspeed Protege
    Last Post: 08-05-2004, 11:08 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
