Show your support and Donate!
Results 1 to 12 of 12
Thread: Trouble Starting and P0171 ECM CEL
  1. #1
    Living the wagon life...
    2003 Mazda Protege5
    Join Date
    Feb 2011
    Location
    Las Vegas, NV
    Posts
    250
    So Ive been spending a lot of time researching the CEL P0171 aaaaaaaaand Im really stumped. But let me back up
    A few weeks back, my P5 started having issues starting. Its gotten to the point where it takes roughly 2-3 times turning the motor over letting it rotate 4-5 times each cycle to get it to start. I can leave it to crank and it takes roughly 10-15 turns before it finally catches... And no matter which way I do it, the motor the starts weak then stumbles up to normal operation.
    Thru my research, Ive replaced the upstream O2 sensor, the cam angle sensor and the crank angle sensor. Since I got the car almost 2 years back, I changed out damn near everything on my fuel system due to the pinging issues our cars experience in the heat. This included brand new parts for everything listed... Bosch fuel pump, OE 1.8 liter coilpacks, NGK plug wires, OE long tip spark plugs, OE fuel sending unit, OE fuel pressure regulator, OE injectors and OE fuel pulsation damper, Mishimoto aluminum radiator, SAMCO hoses and a Mishimoto cooler thermostat (I live in Vegas where its a billion degrees in summer). Ive cleaned the MAF numerous times, I have an AEM short ram intake with K&N conical filter (gets cleaned every few months with K&N cleaning kit) so there are no cracks in my intake piping (ive checked all of the couplers as well). Ive checked all the vacuum lines in the engine bay (outside of the 1 way check valve inbetween the runners of the intake manifold)... havent found a single cracked line. Im about to say screw it and replace ALL of the vacuum lines just so I know that issue is ruled out.
    The car is currently having issues with bogging during acceleration up until around 3500 rpms (this started before the CEL came on). Last Tuesday while driving around, my CEL came on. I pulled the code with an OBD2 reader and started researching, plus replacing sensors that have been listen in regards to the CEL. I cleared the code a few days back, and the CEL came back on today driving over to Lowes.
    So yeah, input please... This code seems to be REALLY vague and its literally like you just have to throw parts at the car until it fixes the problem.
    My 2003 Protege5 5spd aka "Battlewagon" build thread... CLICK HERE
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,618
    Try putting your key to run position and waiting about ten seconds or more before cranking over the engine.
    Some guys fuel rails appear to hold pressure for more than a week... Other people seem to lose pressure in about fifteen minutes. There doesn't appear to be a fuel check valve. I'm pretty sure the pressure is held by the fuel pump impeller itself.
    You didn't mention replacing your PRC solenoid valve... If that is leaking your fuel pressure regulator won't work properly.
    One guy just recently had hard starting and it was due to dirt on his ECT sensor. He cleaned it and the issue stopped.
    The ECU needs to know the engine temperature to do a hot or cold start.
    If it is a hot start, the fuel pressure needs to be higher.
    Make sure your IAT sensor is clean as well.
    If you can get a fuel pressure tester, it will help you trace your fuel system to isolate a fuel related problem.
    It's listed as a Specialty Shop Tool but a generic version would probably work and it might be available as a loan a tool.
    The testing procedure is outlined in the service manual.
    The Diagram Dude
  3. #3
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,618
    When you say you replaced your fuel sending unit you mean this part correct??
    There is a fuel filter inside the housing that can get clogged.
  4. #4
    2003 Mazda Protege5
    Join Date
    Feb 2011
    Location
    Las Vegas, NV
    Posts
    250
    Quote Originally Posted by pcb View Post
    already did this, doesnt change a thing
    theres a small check valve near the fuel rail, im trying to figure out a replacement for it seeing as i cant find a part listing (big surprise for our cars)
    i may be purchasing a new one soon, but this only really effects the pressure inside the tank (from what ive read). the PRC is supposed to relieve excess pressure thats built up due to heat.
    havent checked this, but my coolant system looked clean as a whistle for having over 200k miles on it when i swapped out the thermostat and radiator hoses.
    The ECU needs to know the engine temperature to do a hot or cold start. If it is a hot start, the fuel pressure needs to be higher.
    middle of winter, not a problem at the moment. wasnt an issue either during the summer after i changed radiator/thermostat
    non issue as i clean it every time i clean the MAF, which is usually every 3 to 6 months. cleaned both on Saturday, problems still persist.
    If you can get a fuel pressure tester, it will help you trace your fuel system to isolate a fuel related problem. It's listed as a Specialty Shop Tool but a generic version would probably work and it might be available as a loan a tool. The testing procedure is outlined in the service manual.
    this is most likely going to be my next step... everything is boiling down to feeling like a bad pump at the moment. ive had numerous walbros go out in my S13s over the years and the symptoms feel very similar. probably just gonna go buy an adjustable fuel pressure regulator, a fuel rail and a walbro 255lph pump. even if its not the problem, at least ill be able to add a dash more fuel pressure to see if i can eliminate the pinging issue during the summer given i think the factory tune on my ECM is what causes the issue and it just needs a pinch more fuel pressure to eek out some more gas in those cylinders!
    When you say you replaced your fuel sending unit you mean this part correct??. There is a fuel filter inside the housing that can get clogged.
    yes, i replaced the ENTIRE sending unit with a brand new one from Rock Auto about a year or so back.
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,618
    Quote Originally Posted by dorkidori_s13 View Post
    I think you're thinking that we're thinking about the purge control valve...
    That relates to fuel vapour pressure...
    I'm talking about the fuel pressure regulator solenoid valve. .
    That valve adjusts vacuum sent to the fuel pressure regulator to adjust fuel pressure up and down.
  6. #6
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,618
  7. #7
    Registered Member GJ-Molestor's Avatar
    2011 BMW 528i, 2015 Mazda 6, 1995 Nissan Maxima Manual
    Join Date
    Apr 2017
    Location
    Toronto
    Posts
    1,646
    you said you found a cracked vacuum line... that should be the first place to start. if the car still has trouble starting after taping up/replacing the line, you can rule that out.
    you didnt mention if the car has more trouble starting when hot or cold. or is it the same?
  8. #8
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Springfield, MO Area
    Posts
    949
    PO171 by definition means that the PCM is needing to add much more fuel than the amount it considers to be normal to achieve a decent AFR. If you were to check your fuel trims, they'd be in the high positives, (+20 give or take).
    As for probably causes, vacuum leak, low fuel pressure, faulty 02, etc.
    Maybe the pinging is from your SRI?
    2002 Protege5 5 Speed, Pure White, FSZE Swap, Konig Incident 17's
    1998 Ford Ranger 2.5 5 speed
    2013 Honda CB500F
  9. #9
    2003 Mazda Protege5
    Join Date
    Feb 2011
    Location
    Las Vegas, NV
    Posts
    250
    Quote Originally Posted by GJ-Molestor View Post
    that was a typo boss...
    both
  10. #10
    2003 Mazda Protege5
    Join Date
    Feb 2011
    Location
    Las Vegas, NV
    Posts
    250
    Quote Originally Posted by MrGiggles View Post
    downstream replaced with delphi unit summer of last year. upstream replaced with delphi unit last friday (02-02-18)
    i fail to see how a short ram intake would create a noise that mimics pinging.
  11. #11
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Posts
    949
    More from high IATs.
  12. #12
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,618
    You might want to consider getting an intake that draws from the fender area behind the bumper.
Similar Threads
  1. P5 trouble starting
    By davemsc in forum Protege5
    Last Post: 01-06-2015, 11:52 PM
  2. Trouble starting car
    By bladerunner0427 in forum Protege5
    Last Post: 05-17-2012, 01:07 AM
  3. Trouble starting my car
    By LostSoulx316 in forum Protege5
    Last Post: 12-06-2011, 11:28 AM
  4. Having Trouble Starting
    By jtom in forum Protege5
    Last Post: 01-07-2008, 10:29 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
