VersaTuner - tuning software for Mazdas
Results 1 to 5 of 5
Thread: Bearing help asap.
  1. #1
    Registered Member GiddyKong's Avatar
    2002 Mazda Protege5
    Join Date
    Mar 2015
    Location
    Milwuakee, WI
    Posts
    74
    Bearing help asap.
    I need a new front drivers side bearing. I ordered one, but it was to big. Went to the part store no luck there, even with checking other model Mazda and such.
    Anybody else have this problem? What bearing did you get?
    Silver '02 Protege5
    MP3 ECU Swap
    OBX Header
    Racing Beat CatBack
    Custom CAI
    Mazda6 Front Brake Upgrade
  2. #2
    Registered Member naguilar's Avatar
    2003 Sunlight Silver Mazda Protegé5
    Join Date
    Oct 2016
    Location
    NC
    Posts
    78
    I used Timken 510003 Bearing when I had the job done 2 years ago for my P5. Direct fit and gave me no issues.
  3. #3
    2002 Mazda Protege5
    Join Date
    Mar 2015
    Location
    Milwuakee, WI
    Posts
    74
    That's the part number I ordered.. But it definitely is not the right part.
  4. #4
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,170
    The bearing is really tight and needs to be pressed in.
    I put my knuckle in the oven and the bearing in the freezer and it just fell right in.
    Mazda apparently likes really tight bearings...
    The Diagram Dude
  5. #5
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    252
    I got these off Amazon for about $15 each. Centric 412.90002E Rear Wheel Bearing
    Fit great, no problems at all. It says "rear" wheel bearing but it is for the front of ourcar.
Similar Threads
  1. MSP bad bearing noise turned out to be Axel shaft bearing
    By HCFL in forum Mazdaspeed Protege
    Last Post: 02-26-2015, 10:39 PM
  2. Turbo Bearing Types: Ball bearing, wet float, etc.
    By Metallic36 in forum Mazdaspeed Protege
    Last Post: 10-01-2014, 10:19 AM
  3. I need a passanger side knuckle/hub/wheel bearing assembly thing asap
    By 719prottege in forum Completed Transactions
    Last Post: 09-17-2011, 11:56 AM
  4. Replies: 14
    Last Post: 12-08-2008, 09:04 PM
  5. Changing from ball bearing to journal bearing got ?'s
    By Shadow102 in forum Mazdaspeed Protege
    Last Post: 05-23-2007, 06:38 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
