Made in USA and Free Shipping on all orders shipped inside the US.
Results 1 to 8 of 8
Thread: Side airbag deployed. No other damage. What now?
  1. #1
    Registered Member
    2002 Protege5
    Join Date
    Oct 2009
    Posts
    3
    I've got a 2002 Protege5.
    Short version: My side airbag went off so now my driver's seat has a huge tear and the door panel is damaged. I'm wondering if I can replace the seat and door panel, or is there another way to fix it?
    Long version:
    Because of a bonehead thing I did some time ago (no need for details now), the driver side front door doesn't quite close right, and in the winter the door switch always registers as open. It's annoying but not a big deal, but it led to another bonehead thing I did more recently. Sometimes I'll slam the door after I get in and that will actually close the door switch, for that trip at least. On an extra cold morning recently (maybe related, maybe not), I slammed the door after getting in, and the side airbag deployed. Quite surprising.
    So now I've got a huge tear in the side of the seat, no side airbag, and a damaged door panel where the airbag impacted the door. Any thoughts on what I should do? I was thinking that I might be able to find a replacement seat and door panel at a local junk yard. I'm not sure if I'd actually find those things, and if I do, I'm not sure if there is anything else that would need to be done or reset after the airbag was deployed.
    As an aside, the car has 190,000 miles, it has rust problems (New England winters), and our family could use a larger more reliable car anyway. So I'm considering sending this car out to pasture, despite the fact that the engine runs just fine. Any thoughts?
    Thanks!
  2. #2
    Registered Member
    mazda
    Join Date
    May 2012
    Location
    USA
    Posts
    244
    Have you checked the facebook and forum for sale pages for seats to swap in?
  3. #3
    Registered Member
    2002 Protege5
    Join Date
    Oct 2009
    Posts
    3
    That's a good idea. I'll do that.
    Do you think it would be as easy as swapping in a replacement seat? Do you know if anything else would need to be reset, changed, etc. after an airbag is deployed? I'm not sure what that would be, but just asking if anyone has any experience with this.
    Thanks!
  4. #4
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,180
    There's a whole section on the airbags in the service manual including a symptom troubleshooting section.
    I'm pretty sure that if your airbag system warning light turns off after you start your car then everything is working properly except you won't have your side airbag.
    https://www.mazdas247.com/forum/show...-MSP-MP3-also)
    The Diagram Dude
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,180
    I found this...
    I'm pretty sure you can just swap in a different drivers seat.
    Side airbags were an option and I think most P5's don't have them.
    You could try disconnecting the harness under the seat to see if that sets off the airbag light... If it doesn't, then you could just put in any seat.
    I'm almost positive that if you find a drivers seat with a side airbag, it will plug right in with no problems.
  6. #6
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,180
    Quote Originally Posted by tkotwal View Post
    ... just asking if anyone has any experience with this.
    I'm guessing if anyone did deploy their airbag, they probably totalled their car and aren't on the forum anymore??
  7. #7
    Registered Member
    2002 Protege5
    Join Date
    Oct 2009
    Posts
    3
    Quote Originally Posted by pcb View Post
    Good point.
    Thanks for all your help and advice. I'll look around for a seat to swap in. The manual also says that I should replace the side air bag sensor as well, so I'll see if I can find one of those as well. That's assuming I can find a seat with an air bag. I bet you're right that most P5's don't have them, so those items might be hard to find.
    The airbag light is flashing a code, maybe even two codes. I'll check them in the morning, and will look them up in the manual.
    By the way, I haven't used the forum's for sale page before. Is there an easy way to filter by sellers who are near me? I can't find a feature like that. Shipping a seat wouldn't be worth it, so I'd need to find someone local. Also, do you know which facebook page TheSwapMonster was referring to?
    Thanks again.
  8. #8
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,180
    ...That's assuming I can find a seat with an air bag. I bet you're right that most P5's don't have them, so those items might be hard to find...
    You may have a hard time finding the parts you need or have to spend more than the car is worth to replace them.
    You can probably just swap in an ordinary seat and remove the airbag module from your old seat, reset it somehow and set the module on the floor under the seat so that the computer thinks there is a functioning airbag.
    Or,... You might be able to just simply rub the code,... even by just disconnecting the battery for ten minutes and your good to go ??
    It would be nice to know if the rest of your airbag system is working properly with or without the airbag light flashing. I'm guessing the others will all work because there is a huge danger of the airbag deploying even when it's removed from the car.
    Perhaps a full read of the Restraint section of the Service manual will shed some light.
    On a positive note, you don't have to worry about your side airbag deploying again if you choose to try to "reset" it.
    PS... You've got two electrical connectors under your seat. One for the airbag and one for the seatbelt switch.
Similar Threads
  1. Driver's Side Mirror Damage
    By MSG C5 in forum CX-9 Lounge
    Last Post: 04-11-2013, 02:43 PM
  2. passenger side airbag
    By Tzar177 in forum Mazda MP3
    Last Post: 05-03-2010, 07:30 PM
  3. Driver's seat airbag deployed
    By DeadAir in forum Protege5
    Last Post: 12-28-2009, 09:47 AM
  4. Side airbag ever offered in P5?
    By stockae92 in forum Protege5
    Last Post: 09-30-2004, 05:40 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
