Not everyone who has used H&R's ended up with uneven camber. I've seen some members get even numbers out of an alignment, even with 3" drop corksport springs. I went to the same dealer with my coilovers for an alignment twice, and the second time they (or that tech) couldn't get the fronts at the same camber angle... so I ended up doing it myself.
Also GJ is way off base with his comments... Those statements don't reflects the sentiments of any H&R owner I've come across on this website the CX-5 club FB page, and some of it is just flat out WRONG. My own experience was with a set of H&R's used for over 50k with two Cx-5 until I upgraded to adjustable coilovers.
Fib#1 A set of camber plates is cheaper.. hell to the no. In fact, the only set I know of from Corksport are $360! That's over 1/3 the price of a set of (4) fully adjustable coilovers (Which have camber plates built in the front), or almost 1/2 the price of just two front purchased individually! That is more than the lowering springs not to mention they do not actually lower your car.
Fib#2 Front and Rear sway bars are cheaper.. No Front and rear sway bars are going to run you like $500 if you do the labour yourself, if not expect about 5 hours of labour charge. Not to mention they also *reduce* the independence of your suspension (which could actually cause a shittier ride, albeit with better grip) along with the body roll ; an added effect he left out.
Fib#3 Ride will be bouncy and bad... just flat out wrong. Obviously he isn't speaking from first hand experience, nor is he speaking vicariously.
Fib#3.5/4 Wearing out your struts.. Not sure where he got this from; my oem struts on both of my CX-5 were not worn out at all (prior to installing adjustable coilovers), and I don't recall other owners mentioning this issue on the CX-5.
The players with the least practical experience are always the ones with the most bad info..
You will need an alignment after; you may not be slightly uneven with your rear camber like Paris2 mentioned, likely depending on who performs your alignment.
I’ve spoken with many, many BMW owners who have done all sorts of modifications to their suspensions to know where I’m coming from. There’s probably 1 CX-5 owner modding their car for every 100 BMW owners.... and this was the general consensus when I was over at those forums - you want to lower your car? You do it right the first time with a proper coilover setup such as BC racing.
Thx to all for the input! When venturing into new territory it helps to have feedback from those who have been there ahead of me.
Yeah...I'll probably do the springs and see what happens. If an alignment can't get the numbers where they are supposed to be I'll go ahead and get the extra hardware to allow enough adjustment.
I'm okay with a little firmer ride so if the springs will allow a slight drop and a slightly firmer ride I'll be happy with that.
Truth is I only put about 10K miles on my CX-5 per year and I figure in 2-3 years it will be time to replace the current car so maybe this is a "short term" trial.
chris-top-her: I'm in San Antonio too. Any recommendation for a place to have the alignment done after I get new tires? As well as a place to install the springs?
I'm planning to get General Altimax RT43 225/60 R18 tires. Seems like those are a good all purpose tire that everyone likes. Hope they do okay in the San Antonio summer heat. Any other tires I should consider...that aren't $200USD per tire?
Thx again for any input!
Bill
From previous experience lowering cars, at a minimum, upgrade your front strut and rear shock to one that is meant for lowered cars/shorter springs/progressive spring rates.
When you lower your car with springs without changing your OEM struts/shocks, the shorter/harder springs will wear out your OEM struts/shocks faster. Eventually, this will lead to 'hard' and 'loud' suspension, more noticeable over bump and rough roads.
Example check out Bilstein's B6 vs B8 strut/shock options. One is designed for OEM springs, another for springs that lower a car.
Bill
Just FYI the H&Rs if I'm not mistaken, has a lower drop in the rear. I believe it is 1.25" drop front and 1.75" inch drop rear. If you do not have an AWD CX-5, having the rear lower than the front is not ideal.
As far as OEM struts and lowering springs, I am pleasantly surprised to hear Chris not having any issues with lowering springs. Maybe the CX-5 struts are better than most OEM struts. It is common knowledge though that lowering springs almost always decreases the life of OEM struts. This is because lowering springs will have a higher spring rate, which will not be what the OEM struts are tuned for. With a lowered CX-5, the OEM struts will have to deal with decreased suspension travel and having to dampen a higher spring rate on the springs.
Lastly, there are no Bilstein struts/shocks available for the CX-5. Your only option is to get Koni Sport (yellow) shocks.
The reason for the extra half inch of drop in the rear with H&Rs is to level the suspension. The rear rides higher from the factory to accommodate cargo and rear seat loads.
