I work at a dealership and had service look at it and they said there was nothing wrong with it.
Mazda is becoming more safety conscious in its old age.
Heck, I don't know - just get used to the new arrangement. A little more warning can't hurt. Now, if she completely shuts down at 1/4 tank - THEN - you've got a real problem to deal with it. I'll take the reserve and tell the dealer to keep the other cards in the deck while I play my hand.
On the other hand there is this thought. I recently had something like 5 miles showing on the gauge - the needle was sinking down under and approaching Australia, so to speak. Something happened - don't remember what it was now - but I subsequently began romping on the throttle and having a little fun. I saw some triple digits - no traffic - all safe. Lots of WOTs. Basic fun stuff. As I went for another WOT, suddenly the engine lugged. I was right near a gas station when this happened just by chance. I rolled off the freeway exist (very fortunate) and straight into the gas station on a well timed (lucky) green light through the intersection with the engine now begging for liquid it could burn. I shook my head not because I did not know how this happened, but because I allowed it to happen. I simply forgot - I was having so much fun.
I changed the fuel burn on the vehicle with all the WOT and runs to triple digits. That also changed the projected range. At that level of aggressiveness on the throttle, I never had 5 miles to go - not even close. Fortunately, the exist, green light and gas station were aligned like stars in the sky. You can't make this stuff up.
Moral? This engine (most engines) in particular drinks fuel like a prehistoric animal at WOT and higher RPMs. Yet, it sips fuel like a Humming Bird at low throttle and lower RPMs. This has everything to do with the way Mazda engineers designed the powertrain (engine and transmission combined). So, the vehicle does exactly what it was designed to do in this regard. When you drive it like you stole it, your fuel econ will suck eggs. That's just the way it is. In return however, Mazda engineers give you PLEASURE at higher RPMs. My Corvette was similar. The LS1 V8 would cruise forever on a single tank of fuel in 6th gear (OD) sipping fuel down low on the RPM curve and holding 65 easy. But, once I started banging off of red line in the lower gears and then holding 4th gear while squeezing every bit of energy I could get until shifting to 5th somewhere triple digits (I'm not saying), the fuel burn tanked it drank fuel like an old school Saturn Rocket.
Some engines maintain a level of civil fuel burn at higher RPM than others. But, the most enjoyable engines I've ever had did not have that civil characteristic. They were either flat out fun and drank fuel like a Sailor, or flat out civil and sipped like a prima donna at a cocktail party. They could not be both
at the same time.
That reserve is probably there to protect you from yourself, or from some unexpected need to drive somewhat more spirited until you reach the pump.
