Compare auto reliability with reliable results at TrueDelta.com!
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: HELP! Loss of Power!!!
  1. #1
    Registered Member
    Mazda Protege5
    Join Date
    Feb 2017
    Location
    Kansas City
    Posts
    6
    Alright guys I need your help! This is my first Protege 5, my background is in Jeeps. This past weekend I replaced 1 ignition coil(cracked and broken when pulled out for plugs) and all spark plugs. Now the issue I am having is when I floor my car(5 speed) it jerks like it is losing fuel or something and I lose ALL power. When I say power I mean the car has no pull to it, it struggles so badly trying to accelerate( who am I kidding it doesn't accelerate). I also noticed that I decelerate a bunch when going up any kind of hill, I could be going 70 coming up to a small hill and my car will lose all acceleration and drop to 50 mph or below. I have no check engine light on or anything... any ideas what could be causing my extreme loss in power???? Any and all help is appreciated!
  2. #2
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    252
    How did the old plugs look when you removed them? And was it doing this before you did the work over the weekend? Or did it start after you did the coil and plugs? What plugs did you use? Gap?
    Right off hand, i would suspect either ignition coil. They've been known to be problematic in these cars, even bad right out of the box. I would also check the timing belt for wear. When they get stretched to a certain point they will still run but have no balls at all (not that the car has a lot of balls to begin with). Check for a plugged cat. Possibly MAF sensor is dirty as well. And may want to do a compression test just to rule that out, especially if you just bought the car and have absolutely no idea of the maintenance history.
  3. #3
    Registered Member
    Mazda Protege5
    Join Date
    Feb 2017
    Location
    Kansas City
    Posts
    6
    Quote Originally Posted by pb4ugotobed View Post
    Thank you for the reply! The old plugs were horrible, almost like they had never been changed. I put in some copper plugs, can't remember the brand now. As far as the symptoms being there before changing plugs, yes it was starting to do it which is what led me to look at the plugs to begin with but it was no where near as bad as it is now. The gap I used for the plugs was .044
    As far as checking the cat to see if it is plugged how would I go about that? I have never had a cat get plugged or start going bad before.
    Again thank you for the help I will check these items out and see if that helps any
  4. #4
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,180
    I'm with pb4ugotobed,.. I'd start with coils... They are a fussy PITA for our car.
    Here's the big list of things to consider for a lack of power.
    It mentions the timing belt skipping a tooth which I've heard of before to cause a rough running engine. (much the same as a stretched belt like pb4ugotobed mentioned)
    Your T-belt may still be original. A lot of people neglect to replace it.
    The Diagram Dude
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,180
    Quote Originally Posted by MGriff013 View Post
    Look For This !!!
    If your cat is being bad it may be plugging your exhaust !!
    lol
  6. #6
    Banned GJ-Molestor's Avatar
    2011 BMW 528i, 2015 Mazda 6, 1995 Nissan Maxima Manual
    Join Date
    Apr 2017
    Location
    Toronto
    Posts
    1,806
    sounds like a defective ignition coil to me. I had the exact same situation with my BMW (misfire, loss of acceleration at high RPM)
    and it was a faulty ignition coil.
  7. #7
    Registered Member
    Mazda Protege5
    Join Date
    Feb 2017
    Location
    Kansas City
    Posts
    6
    Thank you all for the responses. I took the car out this morning before work to see if it was still having issues after sitting for a day or so, and I got a flashing check engine light. I took a scanner tool to it and of course for got to write the codes down but had two codes for a misfire in cylinders 2 and 3... also had a code for bank 1 running rich
    This is sounding like a coil issue from everything I have been able to find, does that seem right to you guys?
  8. #8
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,180
    Yea,.. That's coils...
    An engine misfire (Code P0300-P0304) is the only code that flashes the cell on our car. Once the ECU gets the misfiring under control (by going into stupid mode (limp mode)), the light stops flashing.
    The checklist above mentions sparkplug leakage,... The coils like to leak their spark directly to the valve cover... They are more inclined to arc under heavy load.
  9. #9
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,180
    ... but had two codes for a misfire in cylinders 2 and 3...
    Cylinders 2 and 3 are run off the same coil...
    Your codes (P0302 & P0303) point directly at that coil.
    Which one did you replace ??
    Your running rich code should clear after stopping the misfire issue.
  10. #10
    Registered Member
    Mazda Protege5
    Join Date
    Feb 2017
    Location
    Kansas City
    Posts
    6
    Quote Originally Posted by pcb View Post
    I replaced the coil that connects to cylinders 2 & 3... looks like I need to replace it again
  11. #11
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,180
    Don't forget to check your cat !!
    It could still be a cat behaving badly !!
    lol
    I had a dirty cat once,... It was pretty fouled !!!
    It cleaned up pretty nice in the sink though...
    It's been working fine ever since !!
    lol
  12. #12
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,180
    It only takes a couple of minutes of misfiring to burnout your pre-cat...
    You might want to go somewhere else for your coils... Or at least try a different brand if you can get a refund.
    Apparently Polish coils are good quality but the OEM ones are a lot of money.
    An original OEM supplier would be smart (but I don't know who they are)
  13. #13
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,180
    You should really consider replacing both coils...
    I didn't wait for my coils to fail before I replaced them.
    After hearing about all the problems they can cause I just got new ones... I went with Beck-Arnley from RockAuto and they've been good for over five years now.
  14. #14
    Registered Member
    2002 Protege5
    Join Date
    Jan 2018
    Location
    GA
    Posts
    6
    Look For This !!!
    lol
    Lol, she's too adorable to blame.
    Start with the ignition coil.
  15. #15
    Registered Member
    Mazda Protege5
    Join Date
    Sep 2016
    Location
    CA
    Posts
    156
    Thoughts on these? I'm looking to replace my coils as well.
Similar Threads
  1. CAI loss in power
    By YouDontGnomeMe in forum Mazdaspeed Protege
    Last Post: 08-29-2012, 04:55 PM
  2. Loss of Power TSB
    By ZoomFive in forum CX-9 Engine & Transmission
    Last Post: 10-06-2008, 11:25 PM
  3. CAI power loss
    By coyfish in forum Mazda6 Engine & Transmission
    Last Post: 08-10-2008, 09:38 AM
  4. loss of power,y?
    By fasaba in forum Mazda Protege
    Last Post: 01-26-2007, 12:07 AM
  5. loss of power
    By Jswillmon in forum Mazda How-To
    Last Post: 09-10-2003, 06:38 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
