VersaTuner - tuning software for Mazdas
Page 1 of 4 123 ... LastLast
Results 1 to 15 of 47
Thread: Rear laterial mayham.
  1. #1
    Registered Member
    02 protege5 ES 5dr
    Join Date
    Jul 2016
    Location
    Calgary,AB
    Posts
    195
    So today I am helping a fellow p5 local out. His rear lateral looks like this. ( See picture ).
    I have a parts car avalible to him, how ever mine is a slightly less ( to coin PCB's turn of phrase ) rusted turd. And I am having problem removing the non shattered laterial. The nut is free but how does one remove the bolt ( pin ? ) It came free one the wheel nut end. Just fighting like a mo'fo with the pin through the rear sub frame.
    Any thoughts or guidance would be greatly appreciated.
  2. #2
    Registered Member
    02 protege5 ES 5dr
    Join Date
    Jul 2016
    Location
    Calgary,AB
    Posts
    195
    The one I am aiming to use as a replacement is this:
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,804
    I've never had mine apart (and I hope I never have to) but I think that bolt goes through a metal "sleeve" and the two are rusted together, so even if you get the bolt to move, they're still seized and will just spin.
    Some fire might help but I think the gas lines are right above it and that would be dangerous.
    All I can think of is your grinder again like the shifter linkage you did but that big cutoff wheel would probably hit the bracket... Maybe go in at a 45 angle ??
    Maybe get a cutoff saw (if you didn't already buy one) with a metal blade and cut the pin at both sides inside the bracket.
    If you hack away some of that rubber the saw blade may fit in there.
    A little bit like this... I had a bolt break and was catching on my strut,.. I wedged the saw blade in there and cut the stud.
    The Diagram Dude
  4. #4
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,804
    Quote Originally Posted by horseflesh View Post
    ..And I am having problem removing the non shattered laterial.
    You can probably use the grinder and just sacrifice the bracket for that one then pound out the stud after it's removed,... Just like your shift linkage.
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,804
    Yea,.. There's that metal sleeve... I'm sure there one on both ends of the lateral link.
    The bolt and sleeve are fused together.
  6. #6
    Registered Member
    02 protege5 ES 5dr
    Join Date
    Jul 2016
    Location
    Calgary,AB
    Posts
    195
    Quote Originally Posted by pcb View Post
    Yeah, so out of curiosity what would the part number be for the pin / bolt. I can find the lateral links them selves but no mention of hardware included. I am guessing a dealership part ?
    Lol so plan b we just looked at a clean protege DX that wasn't rusted to shit for $500 cdn. Don't want him to pull trigger to quickly.
  7. #7
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,804
    There was a download for all the part numbers few years back but I lost the file and can't find it online anymore.
    You could probably buy something at a hardware store that will work... Shouldn't matter if there is threads or not inside the sleeve part.
    Take the nut with you and find something the right length that it threads on to.
  8. #8
    Registered Member
    02 protege5 ES 5dr
    Join Date
    Jul 2016
    Location
    Calgary,AB
    Posts
    195
    Well, lol dropping entire rear sub frame from parts car, will see if I can't swap it as one assembly.
  9. #9
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,804
    I found all the info for our car,.. Including parts.
    https://www.mazdas247.com/forum/show...-MSP-MP3-also)
  10. #10
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,804
    I hope you don't run into any weld nuts.. They love to break free and start spinning.
  11. #11
    Registered Member
    02 protege5 ES 5dr
    Join Date
    Jul 2016
    Location
    Calgary,AB
    Posts
    195
    Two of four down, first sub frame lol. Using box wrench not socket. Going slow heating and hitting with penetrating oil.
    Yeah and I realized as I stared at the manual, that it has parts listing. I mean derp. And thanks for the link as it is now on my phone as well. Heh.
    Realized that parts car is missing rear sway bar. Going to have investigate that further.
  12. #12
    Registered Member
    02 protege5 ES 5dr
    Join Date
    Jul 2016
    Location
    Calgary,AB
    Posts
    195
    Funny thing about this is; service manual states step one of removing that is removing sub frame.
    Ahem, step one... ( Pauses and wonders how I could have missed that first time out here. Wtf ).
  13. #13
    Registered Member
    02 protege5 ES 5dr
    Join Date
    Jul 2016
    Location
    Calgary,AB
    Posts
    195
    Sub frame dropped. Broke two bolts but the nuts are still intact on the inside of frame ( thank god whew ).
  14. #14
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,804
    So now you need to remove the subframe from your friends car without breaking any bolts or you won't be able to mount the replacement,.. Correct ??
    So those were weld-nuts ?? I didn't know if they were used for such big bolts.
  15. #15
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    219
    wouldn't you be able to just cut them off and weld new nuts to the frame? Seems like a lot less work to do that than to fight with all that rust... at least that way you could start with all new hardware and cost you all of about $2 at the local hardware store for some grade 8 hardware that won't rust like that.
Similar Threads
  1. Replies: 6
    Last Post: 07-01-2017, 08:05 PM
  2. Replies: 2
    Last Post: 10-27-2011, 12:08 AM
  3. WTB OEM protege MSP stock rear engine mount or RR-Racing rear inserts
    By meGrimlock in forum Completed Transactions
    Last Post: 09-12-2011, 10:31 AM
  4. Replies: 3
    Last Post: 01-31-2011, 03:51 PM
  5. Replies: 3
    Last Post: 08-16-2006, 11:17 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
