Compare auto reliability with reliable results at TrueDelta.com!
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: Rallycross BJ Protege
  1. #16
    Registered Member
    00 Protégé LX
    Join Date
    Jan 2018
    Location
    South Central PA
    Posts
    27
    To keep things a bit cooler in the cabin, I added a rally roof scoop. This also adds positive pressure inside the car to keep the dust down. I centered things up and held my breath as i cut into my roof
  2. #17
    Comp Engineering Student Riot_Polizei's Avatar
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    411
    Nice man, I've never seen a roof scoop IRL before, so this is pretty interesting.
    Do you have plans to pull the A/C?
    2002 Mazda Protege5
    ■ Sunburst Yellow ■ Black Rear Valence ■ Injen Cold Air Intake ■ Racing Beat Catback Exhaust ■ Moog Front Endlinks
    ■ Megan Racing Rear Strut Tower Bar ■ Racing Beat Rear Sway Bar ■ Mazda6 Front Big Brakes ■ Foglight Deletes
    ■ OBX 4-1 Headers ■ MP3 ECU ■ VTCS-less Intake Manifold ■ Mishimoto Aluminum Racing Radiator + Fan Shroud
    ______________________________
  3. #18
    Registered Member
    00 Protégé LX
    Join Date
    Jan 2018
    Location
    South Central PA
    Posts
    27
    AC does work there is a leak somewhere. I recharge it periodically but it's not a huge priority for me to try to fix it right now. I'm in prepared front-wheel-drive class in the prepared class they do not allow you to pull for the AC components but it is talk about changing that rule for 2019
  4. #19
    Registered Member
    2001 Mazda SP20 323
    Join Date
    May 2017
    Location
    Hamilton, NZ
    Posts
    61
    This thing is rad! Love the skid plate and light bar setup.
    What's the rules around weight reduction, how much stuff do you have to keep?
  5. #20
    31N007 KingOfSpades007's Avatar
    Mazda Protegé5
    Join Date
    Dec 2011
    Location
    Canton, MI
    Posts
    698
    In Prepared class, a quick glance at the rules says seats can be changed, but I think Modified class is where accessories (power steering, air conditioning, etc) and remnants of the interior can start to be removed. (Rule 3 under Modified reads as follows: All non-essential componentsmay be removed,replaced orrelocated for
    the purpose of weight reduction [...].
    I need a brain.
    2002 Protege5
    Performance
    TWM SS
    CS shifter bushings
    Fidanza flywheel
    Eibach springs
    Tokico Illumina 5 way adj. struts
    AWR MM (all 4)
    RE71R on Filk FTDs
    Visual
    JDM tails
    Mini H1 7.0 35W 4500K
    1996 Subaru Impreza Outback
    Winter beater
    1993 Ford Escort GT
    "The Rally-X Pig"
    That cone looked rather tasty...
  6. #21
    Registered Member
    00 Protégé LX
    Join Date
    Jan 2018
    Location
    South Central PA
    Posts
    27
    Only real weight reduction you can do in prepared is changing of the front seats, same wheel, battery, and lightweight flywheel
  7. #22
    Registered Member
    1999 Mazda Protege ES
    Join Date
    Jul 2018
    Location
    Washington
    Posts
    2
    I have to say that spray can job looks pretty good for what it is. Looks like a ton of fun driving out there too. How does the celica MAF work though?
  8. #23
    Registered Member
    00 Protégé LX
    Join Date
    Jan 2018
    Location
    South Central PA
    Posts
    27
    Quote Originally Posted by iamstd2 View Post
    The 1.6 shares the same MAF that Toyota uses of the Celica and with some cold air setups the OEM doesn't meter the air correctly but the Celica MAF just smooth everything out
  9. #24
    Registered Member
    1994 Mercury Tracer
    Join Date
    Aug 2018
    Location
    Aurora, IL
    Posts
    7
    Very cool!
  10. #25
    Registered Member
    00 Protégé LX
    Join Date
    Jan 2018
    Location
    South Central PA
    Posts
    27
    i haven't updated in a bit so...
    new instagram handle is Rallytege https://www.instagram.com/rallytege/
    so i finish off this year with 1st place in PF Class in my home scca region (Susquehanna) and 2nd in DC region can't wait for next year. working on a LSD for for the f-series trans plus a 1.6l miata lightweight flywheel and some poly mounts in the off season.
    clay was so hard we lay tire marks
    so last year I when up north for some snow racing in a buddies Celica hope to do it again this year weather permitting
    me last year
  11. #26
    crazy tire guy tireboy's Avatar
    91 323 dx
    Join Date
    Feb 2008
    Location
    williams lake b.c.
    Posts
    55
    Looking forward to the new updates...
  12. #27
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    411
    Sweet shots! Good to hear from you about your build again.
    Am definitely interested in how that flywheel installation will go.
  13. #28
    Mazda Protegé5
    Join Date
    Dec 2011
    Location
    Canton, MI
    Posts
    698
    Here's to you not running into the same issues we did installing a Miata flywheel into our G series box on the Escort GT; if you've not yet installed everything else, do yourself a favor and hook the slave back up and have a feel of the engagement from in the car. We had to shim the pivot fork with a washer as the engagement was obscenely low. Looking on RockAuto, the flywheels interchange, so I'm doubtful any issues will arise.
    Chuffed to see an update, and one that includes great news at that!
Similar Threads
  1. Sooo...anyone RallyCross?
    By cealer in forum Protege5
    Last Post: 09-18-2014, 04:10 PM
  2. anyone rallycross their msp?
    By warrier04 in forum Mazdaspeed Protege
    Last Post: 04-27-2010, 06:08 PM
  3. MS P for Rallycross
    By dirtdog in forum Pics & Builds
    Last Post: 07-31-2007, 11:36 AM
  4. March 25 RallyCross!
    By Rally Ninja in forum Global
    Last Post: 03-09-2007, 02:46 AM
  5. Rallycross
    By Rogue in forum Pics & Builds
    Last Post: 01-17-2006, 05:18 AM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
