Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 3 of 3
Thread: Master cylinder replacement with or without ABS?
  1. #1
    Registered Member
    Protege 5
    Join Date
    Nov 2017
    Location
    Canada
    Posts
    101
    Mechanic says I need a new master cylinder. I was looking them up on RockAuto and see some that say 4 wheel ABS and others that say w/o ABS. Question I have is that if the car originally has 4 wheel ABS why would one choose a master cylinder without ABS? Unless I'm missing something here?
  2. #2
    2008.5 MGM MS3 rsvinylgraphics's Avatar
    Donated: $5
    Join Date
    Oct 2009
    Location
    Indiana
    Posts
    1,093
    Well, I believe not all Protege 5's came with ABS, it was an option.
  3. #3
    Registered Member
    Protege 5
    Join Date
    Nov 2017
    Location
    Canada
    Posts
    101
    Ah, Ok thanks. I thought it was standard.
Similar Threads
  1. Clutch master cylinder replacement tips
    By pkthomas in forum Mazda5 Engine & Transmission
    Last Post: 12-31-2016, 01:01 PM
  2. Clutch master and slave cylinder replacement
    By elightbo in forum Mazda Protege
    Last Post: 06-01-2015, 09:50 AM
  3. Clutch master cylinder replacement
    By bwhiting in forum Mazda5 Engine & Transmission
    Last Post: 02-19-2015, 01:48 PM
  4. Brake Master Cylinder replacement
    By m5jrw in forum Mazda5 Wheels, Tires, Brakes & Suspension
    Last Post: 10-05-2014, 07:52 PM
  5. Warning Lights/Master Cylinder & Brake Booster Replacement
    By Renovatorbear in forum CX-9 Wheels, Tires, Brakes & Suspension
    Last Post: 09-03-2009, 03:57 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
