Made in USA and Free Shipping on all orders shipped inside the US.
Page 6 of 8 FirstFirst ... 45678 LastLast
Results 76 to 90 of 115
Thread: 02 PR5 Crank, No Start
  1. #76
    Registered Member
    Mazda Protege5
    Join Date
    Jan 2018
    Location
    Garden Grove, CA
    Posts
    44
    Finally got around to working on the car. Tested for continuity on the alternator plug and it was fine so I decided to just swap out the alternator. The car is now up and running and driving perfectly, but I still have one issue. The airbag light is still flashing 6 times periodically and it wont go away. Maybe a problem with the airbag/srs module? Pls help hahah
  2. #77
    Registered Member
    Mazda Protege5
    Join Date
    Jan 2018
    Location
    Garden Grove, CA
    Posts
    44
    On a side note I feel like i should start a new thread for this issue, or there might already be one. :/ oh well
  3. #78
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,465
    Looks like your your drivers side airbag module... (or it's wiring)
    It's covered in the restraints section of your downloaded service manual.
    Read through the section very carefully before you start working on it.
    The airbag could be set off easily and you could get really injured.
    Play it safe and know exactly what to do before you start.
    The Diagram Dude
  4. #79
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,465
    Quote Originally Posted by PR5Zach View Post
    Tested for continuity on the alternator plug and it was fine so I decided to just swap out the alternator. The car is now up and running and driving perfectly,...
    Check the voltage at the battery terminals... It should read about 12 V... Then start your car and check the voltage again. It should jump up to 13-14 V.
  5. #80
    Registered Member
    Mazda Protege5
    Join Date
    Jan 2018
    Location
    Garden Grove, CA
    Posts
    44
    Airbag light is off for now. As I was trying to test the horn because I’ve never used it, I must’ve shifted some wires or something because the light is now off. Final problem is the damn speedo and the CEL.
  6. #81
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,465
    Quote Originally Posted by pcb View Post
    You may have a fried cluster...
    You can test it yourself to see if the gauges are working...
    You need to use your door switch to enter the test mode...
    If the key reminder dings when you open your door, or if the door ajar light comes on, then your switch is working.
    Do this to see if your speedo is working.
    And get your codes read.
    Apparently auto zone does it for free if you haven't gotten the ELM327 yet.
  7. #82
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    281
    You'll probably have to replace your clock spring some time in the near future. They can have an intermittent break in the wiring of the clock spring (or some call it a spiral cable) and cause what you're seeing. It can also cause the horn, cruise control, or any other buttons on the steering wheel to not function or function intermittently.
  8. #83
    Registered Member
    Mazda Protege5
    Join Date
    Jan 2018
    Location
    Garden Grove, CA
    Posts
    44
    Quote Originally Posted by pb4ugotobed View Post
    could this also be causing the speedo to not work? Because the horn and cruise control don’t work and it points to the clokcspring like you said.
  9. #84
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    281
    It shouldn't have anything to do with the speedo, no. The speedo not working MIGHT also be causing the cruise control to not work if the speed sensor is not hooked up correctly at the trans. But generally if the horn and cruise control both stop working at the same time, it is the clock spring going bad. Depending on where the break in the cable inside the clock springs is, also will usually be accompanied by an airbag light (i believe our car flashes 6 times). I don't recall if you had an airbag light or not and don't feel like reading now lol
    you may replace your clockspring and have the horn and stuff start working and also find that the CC still won't work if the speedo does not work. Some cars the CC is wired directly through the ECM. Some cars the CC routes through the instrument cluster and then to the ECM. I don't know how ours is set, but i'm sure pcb will step in with about 14 wiring diagrams, trouble code charts, etc
  10. #85
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,465
    ...The speedo not working MIGHT also be causing the cruise control to not work if the speed sensor is not hooked up correctly at the trans.
    That makes sense to me... On my car, the cruise control will not engage until the speed is exactly 40 km/hr or above.
    That means the car needs to know exactly what speed it is going (and your car most likely thinks it's zero M/hr)
    If the car has ABS then the ECU gets it's speed info from the wheel speed sensors.
    If it doesn't, then the speed info comes from a gear in the transmission.
    You may have a problem with the wiring going to the steering column or the way your ECU is receiving speed info.
    More diagrams to follow.
    PS.. I'm glad your car is up and running,... It shouldn't be too long till you get the bugs ironed out.
  11. #86
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,465
    Check your GY/B wire (gray with a black stripe) and make sure it goes from the ABS head unit to the ECU. Check for continuity.
    I'm assuming you have a standard transmission with ABS.
    Here's another diagram that isn't included in the PDF download.
    Make sure X, W, Q, and Y all have continuity... You may have to cut and splice wires like you did for the fuel pump.
    I suppose it's possible that the ABS head unit maybe fried as well ???
    Maybe take your car for a spin and hammer the brakes really hard to see if they engage ?? (it feels like your skidding on gravel).
    But you'd probably have your ABS light on if there's a problem with the system ?
  12. #87
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,465
    ...Because the horn and cruise control don't work....
    Check the horn relay...
    Put your finger on it and you should feel and hear it clicking when you press the horn.
    You may simply have a dead horn if the relay is clicking.
  13. #88
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,465
    Have you done this yet ??
    You need to find out if your speedo gauge is working.
    It just takes a few minutes.
  14. #89
    Registered Member
    Mazda Protege5
    Join Date
    Jan 2018
    Location
    Garden Grove, CA
    Posts
    44
    I haven’t in fact and I’m lagging on it. Imma get around to checking everything today and checking the continuity
  15. #90
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,465
    It's easy dude.. Just do it...
    I did it just for fun..
    (all my gauges are working properly !!)
Similar Threads
  1. No Crank, No Start, Help Please!
    By nyyankees2k3 in forum Protege5
    Last Post: 11-03-2017, 07:02 AM
  2. Crank no Start
    By Keatonc in forum Mazda MP3
    Last Post: 11-05-2014, 09:44 PM
  3. Crank but no start
    By reynoldsrobbie in forum Protege5
    Last Post: 10-24-2012, 06:22 PM
  4. Cold start at 32F, no crank 1st/2nd attempt but start?
    By Marik123 in forum Mazda Protege
    Last Post: 01-03-2010, 11:24 AM
  5. 626 will crank, but not start
    By jalbao in forum Other Mazdas
    Last Post: 04-27-2008, 10:57 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
