Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 8 of 8
Thread: Protege5 Manual Transmission Options
  1. #1
    Registered Member
    03 Mazda Protege5
    Join Date
    Dec 2017
    Location
    Memphis, TN
    Posts
    3
    Hey Guys,
    I'm new to the forum and did try searching but couldn't find much info. I'm trying to locate a used manual transmission for my 2003 Protege5 w/o ABS. I've heard of people doing swaps from mid 90's Ford Probe's, Mazda 626's, and standard Protege but can't get confirmation on if it's a direct swap.
    Can someone please confirm what transmissions would be a direct swap with little or no modification?
  2. #2
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    440
    1993 1997 Mazda 626 4cyl Transmission / 1993 1997 Ford Probe
    Engines:
    1993-1997 MX6/Probe 2.0L FS
    1993-2002 626 have 2.0L FS
    1993 1997 626 / Probe Vehicle WITHOUT ABS
  3. #3
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    440
    If its a 2.0l protege that will also work of someone as more info that can chime in would be good.
  4. #4
    Registered Member
    03 Mazda Protege5
    Join Date
    Dec 2017
    Location
    Memphis, TN
    Posts
    3
    Thanks for the info! I found one out of a 1999 Mazda 626 for about $200 I was gonna try out. Glad to get the confirmation before I pulled the trigger.
  5. #5
    Registered Member
    2002 Mazda, Protege5
    Join Date
    Sep 2014
    Location
    Conroe, Texas
    Posts
    3
    Whatever vehicle you find to get your used tranny be sure to use your original vehicle speed sensor or the speedometer will not be correct
  6. #6
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    282
    a good resource is also going to www.car-part.com it is a junkyard search engine and will check all of the large junk yards in whatever area you specify.
  7. #7
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,470
    Quote Originally Posted by arenfro View Post
    ^^^ What he said.
    Cars with ABS get their speed info from the wheel speed sensors.
    Cars without ABS get their speed info from a speedo gear installed in the transmission.
    ABS cars don't have that gear...
    I don't know if the gear is different on other makes and models.
    The Diagram Dude
  8. #8
    Registered Member
    03 Mazda Protege5
    Join Date
    Dec 2017
    Location
    Memphis, TN
    Posts
    3
    Thanks for the advice guys! I ended up getting one from a 99 mazda 626 and it was a straight swap with zero issues. Got the old one out and new on installed in about 8 hrs last weekend. I wasn't sure if the speed sensor would cause an issue or not but swapped it anyways just cause I knew mine was good and it's a pain to reach later.
    The site mentioned above is a great resource that was very helpful in locating the trans but it didn't do the cross reference from my Protege5 to the 626 or the probe so I just used it to search for each separately.
Similar Threads
  1. WTB: 5 Speed Manual Transmission For Protege5
    By Dimentio in forum Want To Buy
    Last Post: 10-07-2016, 11:55 AM
  2. Jeep renegade all options in manual transmission??
    By eclypsecl in forum CX-5 Lounge
    Last Post: 02-23-2015, 03:02 PM
  3. 2003 Protege5 with manual 5-speed transmission ECU
    By PowerHungry in forum Want To Buy
    Last Post: 01-27-2014, 06:39 PM
  4. WTB: Protege5 with Manual Transmission
    By patinum in forum Completed Transactions
    Last Post: 05-27-2011, 03:29 PM
  5. Manual Transmission going...replacement options?
    By jrsmith in forum Mazda Protege
    Last Post: 02-23-2009, 12:40 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
