Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 14 of 14
Thread: Subwoofer placement question.
  1. #1
    Registered Member
    Protege 5
    Join Date
    Nov 2017
    Location
    Canada
    Posts
    101
    My car was already wired up for a sub (sub was taken out as well as amp pre purchase) so I've been thinking about putting one in. Issue is I want my trunk space and my spare tire. Only option I think that would work is what another user here posted in an old for sale item, an enclosure in the rear trunk left hand side empty space:
    Not sure where I'd put the amp, also I have no idea how to build an enclosure. Want to avoid rattling the car. I don't need crazy bass, just enough to give me a decent bottom end. Not sure where else I can put a sub(s). Any ideas?
  2. #2
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Springfield, MO Area
    Posts
    969
    Those enclosures are made of fiberglass. Not really expensive but it requires a lot of patience and time. You need to line the area with plastic or tin foil, apply resin, then mat, then more resin, then cut out an MDF ring where you want to place the sub, glue the ring in place with dowels, stretch cloth around the ring to the backing that you glassed earlier to create the enclosure, apply resin, then mat, rinse and repeat. And when that's all done, sand, trim, and finally paint or carpet. If you search around there are a lot of DIY articles on the process.
    There are a lot of small footprint amps that you can stick practically anywhere, under the front seats, behind the cargo panels, etc.
    2002 Protege5 5 Speed, Pure White, FSZE Swap, Konig Incident 17's
    2006 Chevy Silverado 1500 4x4 5.3
  3. #3
    Swollen Member Natey's Avatar
    Donated: $20
    Mazda
    Join Date
    Jan 2003
    Location
    Pleasure Point, California
    Posts
    6,420
    Check out Infinity's Basslink. I had one in my P5 for years.
    Here's on old pic
    https://www.ebay.com/i/332496794494?chn=ps
    NPOT (Norcal Protege Options Team)
    http://www.cardomain.com/ride/335883...photo-gallery/
  4. #4
    Registered Member
    Protege 5
    Join Date
    Nov 2017
    Location
    Canada
    Posts
    101
    Thanks. Guess I'll look up how to do fiberglass molding. I wonder if I can somehow fit an amp in the same area. Will check out other spots I can place speakers.
  5. #5
    Donated: $20
    Mazda
    Join Date
    Jan 2003
    Location
    Posts
    6,420
    Basslink has a built in digital amp.
  6. #6
    Registered Member
    Protege 5
    Join Date
    Nov 2017
    Location
    Canada
    Posts
    101
    Yeah I was thinking perhaps I just want to use something like the KICKER 11HS8.
  7. #7
    Registered Member
    Protege 5
    Join Date
    Nov 2017
    Location
    Canada
    Posts
    101
    The Basslink is an option too though it rolls off at 50hz and I'd prefer something a lil lower like 35hz. I'm now wondering about getting one of those slim powered subs and either placing it under driver's seat or rear passenger seat or if I can wedge it in that concave space in the rear trunk area, as well as if it would sound much different in any these locals.
  8. #8
    Donated: $20
    Mazda
    Join Date
    Jan 2003
    Location
    Posts
    6,420
    If you wanna bump the neighborhood, that custom box ain't gonna do it, from my experience. I had a box that looked a lot like the OP but it rattled and never sounded quite right. I put in a box with a couple 10" subs for awhile, just to piss off the neighbors. It took up too much room though and the Basslink sounded great.
    SQ is something to think about.
  9. #9
    Registered Member
    Protege 5
    Join Date
    Nov 2017
    Location
    Canada
    Posts
    101
    Currently looking at the Kicker 11HS8 under a seat or maybe a bazooka sub that I can move out of the way if I need the rear cargo space. Don't need crazy bass, just some nice low end, I dislike rattling bass.
  10. #10
    Registered Member
    2002 Mazda Protege5
    Join Date
    Apr 2014
    Location
    Los Angeles, ca
    Posts
    4
    If you do the under seat one, please let us know how you like it. I’ve been thinking of getting one of those, but wonder if it’d be “uncomfortable”
  11. #11
    Registered Member
    Protege 5
    Join Date
    Nov 2017
    Location
    Canada
    Posts
    101
    Yeah, gonna pick one up in the Spring. Not sure where I'll place it. Don't know if I want it under my driver seat though, as much as having my cajones vibrating while listening to Drum & Bass might be tempting. Wondering about perhaps under rear seat middle or merely strapping it to that side concave space in the rear cargo area.
  12. #12
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    255
    I just have an oooold school MTX amp under the driver's seat and a boston acoustics 10" sub in a shallow truck box screwed to the back of the drivers rear seat in the cargo area, firing straight backwards. No rattles, sounds great, and doesn't take up any real usable space since the box is only about 5 inches deep. seats still fold down like normal and if i need to remove it to move something big remove the 1 screw and pull it out.
  13. #13
    Registered Member
    Protege 5
    Join Date
    Nov 2017
    Location
    Canada
    Posts
    101
    I know once I get the speaker I'm gonna play around for best placement. Good thing about subs is that the frequencies are omni directional. Basically something that sounds good and doesn't interfere with cargo.
  14. #14
    Registered Member
    Protege 5
    Join Date
    Nov 2017
    Location
    Canada
    Posts
    101
    Well an update of sorts. Still looking at options. One is the PIONEER TSSWX2502 and an amp in the cargo area which wouldn't take up too much room. Also looking at the Cerwin Vega VPAS10.
Similar Threads
  1. Subwoofer placement idea
    By bmarsh in forum CX-5 Infotainment
    Last Post: 01-19-2017, 10:25 AM
  2. Subwoofer question...
    By NTIMD8R in forum Mazda3 Infotainment
    Last Post: 05-03-2009, 02:53 PM
  3. Question about my subwoofer...
    By mrebum in forum Mazda How-To
    Last Post: 01-25-2009, 10:17 PM
  4. Replies: 4
    Last Post: 10-03-2004, 07:49 AM
  5. Subwoofer and amp question
    By 5DOORMAN in forum Mazda3 Infotainment
    Last Post: 09-08-2004, 08:05 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
