Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 31
Thread: 30mm Spacers on 2017 Cx-9 GT AWD
  1. #16
  2. #17
    Registered Member
    2017 Mazda CX-9 GT AWD Machine Gray, 2008 Audi A3
    Join Date
    Mar 2017
    Location
    Liberty Lake, WA
    Posts
    29
    Quote Originally Posted by sm1ke View Post
    vitpk1, did you have to do an alignment or camber/toe correction after the spacers were installed?
    No alignment or any other corrections... I do tire rotation every 5000 mi ( twice so far, I’m @ 10800mi) and tires show even wear
  3. #18
    Registered Member
    Join Date
    Mar 2017
    Location
    Liberty Lake, WA
    Posts
    29
    Quote Originally Posted by Foxy25 View Post
    Hi there, just wondering if you could post a couple of pics at fender height straight down the line showing if there is any poke from the tire? Considering trying this.... Thanks, Foxy
    Front flush with fender:
    Rear 5mm in (no poke):
    And this is how I measured to determine spacer thickness:
    Rear:
    Front:
    Hope this helps
  4. #19
    Work in Progress sm1ke's Avatar
    Donated: $25
    2018 Mazda CX-9 Signature
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    1,919
    Hm. So the front wheel hubs sit 5mm out more than the rears?
  5. #20
    Registered Member
    Join Date
    Mar 2017
    Location
    Liberty Lake, WA
    Posts
    29
    Or perhaps rear fender arches are wider than fronts by design? I’m not sure
  6. #21
    Registered Member
    CX-9 Azami Auspec
    Join Date
    Aug 2017
    Location
    South Australia
    Posts
    28
    Quote Originally Posted by vitpk1 View Post
    Hope this helps
    Thank you VERY much!!
  7. #22
    Registered Member
    CX-9
    Join Date
    Jun 2018
    Location
    Singapore
    Posts
    4
    Yes, it is a pretty straight forward install. One VERY important moment: new spacers must be re-torqued after about 50-75 mi of driving!
    This is a good video about spacers installation:
    https://youtu.be/JPsaiLiNaLo
    hi there, did you have to shorten / replace the factory studs?
  8. #23
    Registered Member
    Join Date
    Mar 2017
    Location
    Liberty Lake, WA
    Posts
    29
    Quote Originally Posted by Twenty-six View Post
    No, I didn’t. No modification to factory studs
  9. #24
    Registered Member SK77X's Avatar
    Donated: $25
    2016 CX-5 GT, 2017 CX-9 GT
    Join Date
    Jun 2015
    Location
    San Jose, CA
    Posts
    210
    So was the reason you still went for 30mm for the rears even though 35mm would have been flush simply due to it being cheaper to buy a set of 4, or was there another reason why you didn't want the rear wheels flush like the fronts?
    Also, I know it's hard to tell since they're still fairly new, but how is the quality of the spacers themselves? These ones are far cheaper than some of the more premium brands so just weary of that since a spacer failure at speed would be potentially fatal.
  10. #25
    Registered Member
    Join Date
    May 2019
    Posts
    9
    SO I want to do spacers on our CX9, Ive never used them before. I think I would like something like 15 or 20mm better, as I want a wider look, but not flush with the fenders.
    So does anyone know, what the minimum spacer width you can do, yet still bolt on using the current studs i.e. the spacer has holes to bolt it on and the studs to mount the wheel (so you dont need to use longer studs)? Obviously there is some minimum to clear the nuts holding the spacer on, not sure what it is.
    Do these 30mm spacer with the nuts holding them to the current hub just clear the nut tops?
  11. #26
    Donated: $25
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    1,919
    I believe that for this style of spacer, the spacer bolts to the existing studs. The spacer then has it's own studs that the wheel would mount to. Here's a video that provides a good explanation:
    I think the minimum width spacer you could use with the OEM studs is 5mm.
  12. #27
    Registered Member
    Join Date
    May 2019
    Posts
    9
    Right, I dont want to change out the original studs to longer ones, and I think just adding a plate spacer like 5mm which can use the original studs isnt enough to get a better look.
    So I want a spacer to bolt to the hub using the original studs like the OP did, but not sure if its possible in a 20mm or 15mm version, because the nuts used to fasten the spacer to the original studs have a certain thickness, and it may be 30mm, so thats the thinnest you can go with this type of spacer. Just wonder if anyone knew the thinnest space with the integrates studs could be.
  13. #28
    Donated: $25
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    1,919
    Quote Originally Posted by corvetteboy6988 View Post
    Sometimes an OEM wheel has "pockets" between the lug holes that would provide space for the OEM studs and lugs when using a spacer thinner than 30mm. See below:
    I don't remember if the OEM wheels have these "pockets" or not, but I can check my winter set when I get home and get back to you.
  14. #29
    Registered Member
    Join Date
    May 2019
    Posts
    9
    Great point, that would allow clearance, I can check my OE 20's, and I can also measure the stud protrusion from the rotor, and figure out how much they will stick out past the 20mm spacer, Im guessing its gonna be more than 1", in which case I need to OE wheels to have the pockets.
  15. #30
    bachman bachman's Avatar
    '16 CX-9 Soul Red/Parchment , Touring
    Join Date
    Jul 2012
    Location
    Colorado
    Posts
    47
    Itís a no brand set from Amazon, that appears to be a good quality!
    4pieces 30mm Hub Centric Wheel Spacers | 5x114.3 5x4.5"| 1.18" Inch Thick https://www.amazon.com/dp/B06XQW6J9S..._Fbl1OCm3MtwoZ
    Nice job on the spacers and the info related.
    Your ride looks extra sweet with that change and I may do the spacer trick on my Vdub sportwagen.
    Per my wife's CX-9, I may research the tire sizes to go slightly taller on her 18's.
    The wheel well looks too big or tires too small. Part of my sporty look to the old G-35 I had was fixing it that way but never got around to spacers. Just tire sizing was a nice trick to make it look better versus lowering, coil-overs, cost, work etc....
    '16 CX-9 AWD, Soul Red / Parchment, Touring (purchased demo with 4800 miles)
Similar Threads
  1. Vogtland 30mm lowering springs P5 323 125.00
    By boyirish6 in forum Mazda Protege For Sale
    Last Post: 12-14-2016, 05:11 PM
  2. Work XD9 Bronze 18x9 +30mm
    By mattism78 in forum Completed Transactions
    Last Post: 01-12-2013, 05:11 PM
  3. 30MM or 40MM
    By Chris_uk in forum Mazda2 General
    Last Post: 03-20-2012, 02:46 PM
  4. 30mm drop????
    By steffenaj14 in forum Mazdaspeed Protege
    Last Post: 06-22-2011, 09:01 AM
  5. 18x8 with 30mm offset
    By mattj3636 in forum Mazdaspeed3
    Last Post: 01-09-2009, 01:55 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
