leonardgermain
- mazda protege 2002
Allright! I have seen a lot of people with that exact problem.
I have read them all. Every each one of them. I have not tried anything, but just by logic, all I see will not get my problem fixed.
As you saw in the title, my tail lights and dashborad lights are all out, including the climate control lights. Headlamps are working good, high beams, and also brakelight are working.
But! I saw people saying things about the grounds, about jumping the circuit because it has a short somewhere where it is impossible to find it, replacing de fuses and the taillights relay and the switch attached to the column etc etc.
The thing is, I have a remote engine starter. For safety measures, when I start the car from a distance, the lights are turning on. Tail lights, dashlight, everything so the car is visible at night if I start it. And when I start it now, with the issue, they all turn on! So there is defenitely no issues with the relays, the circuit and the fuses as everything is coming on.
And then, I put the key in the ignition, turn it to the right position, press on the brake to put the car in drive, and boom, no tail lights and no dashboard lights!
A big what the h*ll right now!
